Author Topic: Brymen BM867 & BM869  (Read 6343 times)
Offline onemilimeterTopic starter
« on: February 19, 2017, 02:39:40 am »
Hi... Wish to purchase one of these meters. Before purchasing, wish to confirm whether these meters can do "LoZ" measurement? Kindly advise. Thanks.
Offline rstofer
Re: Brymen BM867 & BM869
« Reply #1 on: February 19, 2017, 03:24:20 am »
According to the spreadsheet in the stickies for this forum - no...
Offline mtdoc
« Reply #2 on: February 19, 2017, 04:03:37 am »
Yeah, I have a Brymen 257 and it has it but I don't think the 860 series meters do.
You can have a look at all the meter datasheets on the Brymen website
« Reply #3 on: February 19, 2017, 04:16:49 am »
For a meter that does not provide LoZ measurement, can we build an adapter to be used with the meter for LoZ measurement? It's like the uCurrent concept which Dave invented before... Thanks.
Offline Wytnucls
« Last Edit: February 19, 2017, 04:32:41 am by Wytnucls »
The following users thanked this post: Marco1971
Offline DaJMasta
    • medpants.com
« Reply #5 on: February 19, 2017, 06:10:07 am »
My BM867s does not have a LoZ function.
This hasn't been a problem for me, though when I eventually get a second handheld, I will be looking for one.  It really only comes up if you want to discharge a cap that stores its charge for a long time, and most of the large caps I've worked with either have a bleeder or are directly powering circuitry that uses up the charge on them quickly after being powered down.  There's also other methods for discharging such a cap, though it is nice to do it through something with a decent CAT rating.
« Reply #7 on: February 19, 2017, 02:35:19 pm »
https://www.amazon.com/Fluke-SV225-Voltage-Eliminator-Adapter/dp/B005H0NKDC
http://en-us.fluke.com/products/all-accessories/fluke-sv225.html#overview
I wander what is inside that little box (SV225), a shunt resistor?
Probably 2 series connected PTC thermistors and a series resistor, to limit the current to a semi constant value as the capacitor discharges.
steverino
  • Guest
« Reply #8 on: February 19, 2017, 06:43:19 pm »
I have one and took it apart some time ago.  I'll try to get a photo uploaded.  From memory, it had a 1K resistor and a ptc/ntc?
« Reply #9 on: February 20, 2017, 08:13:43 am »
Great !! Hope that you will share the photo soon... Thanks in advance...
steverino
  • Guest
« Reply #10 on: February 21, 2017, 07:49:17 am »
I've attached the circuit diagram.  It's just paralleled with the input jacks of the meter.
« Last Edit: February 21, 2017, 07:54:40 am by steverino »
« Reply #11 on: February 22, 2017, 07:06:44 am »
Many thanks... Fluke distributor just quoted the Fluke SV225 for USD116...  ;D
