At the moment of switch on, this system is not responding to ‘steady state’ ac equations. There’s no magnetic flux, no back emf, and you connect a step voltage. The dv/dt and the di/dt is very high. There will be considerable interaction between the supply impedance and the transformer, so transient effects fully expected- expect an instantaneous current in excess of 100A followed by oscillations to reach the steady state. I expect the transformer is behaving normally.
