The BK power supply looks relatively expensive, even if you take into account that this is the manufacturers suggested price compared to an amazon price.
There max still be a few customers who actually need the slightly higher voltage - if you need 33 V a 30 V supply is not enough.
The KA3005 is more like a bottom end low cost version, that can be that cheap because of the large quantety. Also take into account that it is quite a bit less powerfull: 30 instead of 35 V and actual performance not really up to the promissed specs (e.g. overheating at max current and unfavorable voltage, possible ripple at come voltages and high current). So to be be fair one would need more like 2 of the KA3005.
