This is the code that I am using - sorry it's a bit untidy but i've just hacked it together from different sources:
/* CRC calculation using HP1630 algorythm */
#include <stdio.h>
#include <stdlib.h>
unsigned int CRC_table[256];
unsigned int HP_CRC(unsigned char *,int , int );
void HP_CRC_Initialise(unsigned int);
int main(int argc, char *argp[])
unsigned int n,x,z;
unsigned int crc;
HP_CRC_Initialise(0x8005);
crc = 0;
printf("\n");
for (z=1;z < argc;z++){
n = sscanf(argp[z],"%x",&x);
if (n!=1) {
printf("\nUnable to interpret %s as a hex constant.\n",argp[z]);
exit(1);
crc = (crc & 0xff00) ^ CRC_table[(crc ^ x) & 0xff];
printf("\nCRC = %04X",crc);
printf("\n");
exit(0);
/* Generate table and perform CRC according to HP1630 requirements */
unsigned int HP_CRC(unsigned char *buffer,int length, int seed)
int x=0;
while (length > 0) {
seed = (seed & 0xff00) ^ CRC_table[(seed ^ buffer[x++]) & 0xff];
length--;
return(seed);
void HP_CRC_Initialise(unsigned int poly)
unsigned int crc,x,y;
for (x=0;x<256;x++) {
crc = x;
for (y=0;y<16;y++) {
crc <<= 1;
if (crc & 0x10000) crc ^= poly;
crc &= 0xffff;
CRC_table[x] = crc;
Enter the hex-bytes on the command line separate the bytes with a space.
