Author Topic: Brymen (EEVBlog) BM235 Multimeter Verification to Specifications  (Read 3382 times)
Offline boggis the catTopic starter
For anyone who may be interested, this is the initial data I obtained while verifying my Brymen (EEVBlog) BM235 Multimeter to the manufacturer's specifications.
No uncertainties are present, as I haven't bothered to calculate them.  These will mostly be ±1 count for DC Volts, but can become significant for AC Current (e.g. 50.00 ± 0.18 mA @ 50 Hz).
(PDF has same data as broken out into PNG files.)
Offline Performa01
  • Country: at
Re: Brymen (EEVBlog) BM235 Multimeter Verification to Specifications
« Reply #1 on: March 04, 2016, 10:59:02 am »
Nice calibration protocol, but ...
... what does it actually tell us, other than your particular unit is within spec?
While I have no doubt that this will be true for all the others as well, isn't this a bit overkill for a low accuracy meter like this?
Offline PedroDaGr8
  • A sociable geek chemist
« Reply #2 on: March 04, 2016, 12:26:18 pm »
Nice work, not too many people have the equipment/lab to do this. Will be very interesting to see 6mo and 12mo data points as well. Thanks a bunch for doing this.
The very existence of flamethrowers proves that some time, somewhere, someone said to themselves, "You know, I want to set those people over there on fire, but I'm just not close enough to get the job done." -George Carlin
« Reply #3 on: March 05, 2016, 01:39:46 am »
A single data point doesn't mean much (this could be a rare 'golden unit'), as you are pointing out.
This data set was obtained for comparison with an Owon B35T that I obtained earlier.  That isn't a bad meter, either (aside from the input protection being very dubious), but nowhere near as stable as the BM235.
This meter compares favourably to e.g. the Fluke 179 and is a lot less costly.  The better Fluke meters commonly achieve better than 40% of specification when new, then will hold those specs indefinitely.
This isn't a standard calibration process.  I chose to take 5000 count points instead of the usual ninety percent of range (5400 count) in order to make debiations from nominal more obvious, and also let the meter stabilise for far longer to see if any bias would creep in -- and it does, but only one count here or there, and that could simply be boundary conditions tipping the least significant digit.
I took down ambient temperature and RH, and also checked the auto ranging roll-over points.  I stripped this from the data presented to simplify and improve readability.
While this is indeed 'overkill', I hope it may give a better picture of this meter than can be achieved by most verification methods.  Having a metrology lab at my disposal, it seemed a worthwhile exercise to have a close look at the main functions on this new-to-market meter that Dave is selling.
« Reply #4 on: March 05, 2016, 01:44:56 am »
Thanks for your reply.
I'd like to do some environmental limit tests as well, but our lab doesn't have a chamber.
In any case, the manufacturer's specifications are not wildly optimistic / total lies (delete as applicable).   :-+
