Hello!
I am trying to get a long arb sequence to the DG1062z, 1e6 samples at 5MSa/s, which I created in Python.
The values are between 1.5 and -1.5. I tried with a csv and txt file as described in the documentation. However, I don't get any output (not even for the shorter version).
I have tried everything I can think of, shortening the float to 4 digits, etc.
Sending the same values via SCPI works up to 1500 samples, then a communication error occurs (not unexpected).
Does anyone have an idea what the problem could be and perhaps an example file that I could test?
Thank you in advance!
