Author Topic: Brand new piece of test equipment!  (Read 14343 times)
Lurch
  • Guest
Re: Brand new piece of test equipment!
« Reply #25 on: January 11, 2014, 08:32:54 pm »
So accuracy has improved to 3 digits.
I can think of no situation where you would require any more than that anyway.
Offline Jon86
« Reply #26 on: January 11, 2014, 08:37:12 pm »
So you're saying you would never need more than three digits?
Death, taxes and diode losses.
Offline Lunasix
« Reply #27 on: January 11, 2014, 08:57:15 pm »
Thanks !
Curious that the range is written 10V for example and you can mesure up to 19.9V. Why not write 20V for range ???
Online edavid
« Reply #28 on: January 11, 2014, 09:21:40 pm »
Two and a half, as I said.
(And to be pedantic, that is precision, not accuracy.)
« Last Edit: January 12, 2014, 01:09:28 am by edavid »
Offline Dave
  • Country: si
  • I like to measure things.
« Reply #29 on: January 11, 2014, 11:54:41 pm »
Nope, it's resolution.
Precision would determine how well it can reproduce the result when given the same conditions.
Accuracy tells us how close that measurement is to the actual value.
<fellbuendel> it's arduino, you're not supposed to know anything about what you're doing
<fellbuendel> if you knew, you wouldn't be using it
Offline MadTux
« Reply #30 on: January 12, 2014, 12:39:29 am »
Cool and recently wondered whether there were 2 1/2 digit multimeters while watching this video, since all I could see were 3 1/2 digit:
Offline eurofox
    • Music
eurofox
Offline echen1024
  • 15 yo Future EE
« Reply #32 on: January 12, 2014, 02:55:08 am »
Precision =/ Accuracy
3.14 Accurate, but not precise
3.887897894536748645 Precise, but not accurate
3.141592653589793238 Accurate, and precise
I'm not saying we should kill all stupid people. I'm just saying that we should remove all product safety labels and let natural selection do its work.
https://www.youtube.com/user/echen1024
Offline peter.mitchell
« Reply #33 on: January 12, 2014, 11:42:29 am »
No.
A better explanation is this;
you have a battery, across it is a 1meg resistor, the battery was charged to a perfect 5v at the beginning of each meter connection
you connect your multimeter
you read 5 measurements, these are your readings;
5.0003
4.9997
5.0004
4.9996
5.0000
you connect another meter
5.0014
5.0014
5.0012
5.0012
5.0013
5.00315
5.00312
5.00313
5.00310
5.00308
5.00029
5.00014
5.00003
5.00013
4.99985
5.00000
4.99999
4.99998
4.99997
4.99996
The first meter is accurate, its readings are closer to the real value, so averaging will give you a closer value to the real value.
The second meter is precise, its readings are relatively close to each other, meaning it will give you repeatable results, its error can be "calibrated" to give you a value closer to the real value.
The third meter is of higher resolution and precise, its readings are relatively close to each other, meaning it will give you repeatable results, it's extra resolution makes it easier to detect smaller changes in value, its error can be "calibrated" to give you a value closer to the real value.
The fourth meter is of higher resolution and accurate, its readings are closer to the real value, so averaging will give you a closer value to the real value, it's extra resolution makes it easier to detect smaller changes in value.
The final meter is of higher resolution, accurate, and precise, its readings are very close to the actual value, they are repeatable, and it's extra resolution makes it easier to detect smaller changes in value.
Offline Napalm2002
« Reply #34 on: January 18, 2014, 04:16:50 pm »
Did u snag that off of eBay? I have been watching obe on there and haven't made the move to buy it. Awesome score!
Offline linux-works
    • netstuff
« Reply #35 on: January 24, 2014, 08:08:41 pm »
my latest nixie purchase:
top counter just arrived today.  has 1 bad digit (bad 8 on one of the tubes) but otherwise all working.
(bottom 2 boxes were also recent purchases; I've been doing some home lab upgrades lately) ;)
love the blue vfd, but also have a liking to old style nixies.
Offline dr.dieselTopic starter
« Reply #36 on: January 24, 2014, 08:20:53 pm »
You bastard!  I love it,  :-+
