Author Topic: Brand new Keysight 1204G glitches??  (Read 1487 times)
Offline bestelTopic starter
« on: April 23, 2021, 02:52:22 pm »
 I've bought a Keysight 1204G.
Channel 1 and 2 are doing strange things below 250 MSa/S, with random glitches of only one point :
  • The glitch cannot be triggered
  • Problem disappear when Acquisition is set to average or High-res (normal for a one point glitch btw)
  • Activation of CH3 + CH4 can make the problem disappear on the CH2, but not on CH1
  • None of the bandpass filter, or HF rejection works
  • Glitches appears only on CH1 if CH2 is also on, but on CH2 if CH1 is off
Maybe I'm just missing something but I'm thinking of a hardware fault.
(I've updated the firmware).
I've put some screenshot:
- Glitches on CH2
- No Glitches if I turn on CH3 + CH4
- Zoom of one glitch (there is always one glitch at a time)
I've also noticed that it seems there is no glitch in segmented memory mode.
« Last Edit: April 23, 2021, 03:11:36 pm by bestel »
Re: Brand new Keysight 1204G glitches??
« Reply #1 on: April 23, 2021, 04:32:42 pm »
This is the weirdest thing I ever saw  :o
Maybe it's the ADC (but it's a strange distribution over the time base), or maybe it's a memory corruption.
I think it's a memory corruption because it will explain why the glitches are not triggerable.
But it does not explain why these glitches occurs only on CH1 and CH2, and only below 250MSa/s.
I'm going to perform a firmware upgrade one more time, and maybe a firmware downgrade if it's still not ok.
« Reply #2 on: April 23, 2021, 05:12:51 pm »
Firmware update did not change anything, and I can't find the 2.10 previous version.
The glitches occurrences changes from rare (0.05%) to more often (25%) regarding of the position of the reference.
For example, ref at -3 div = 0.05% of failures, at -2.5 div = 25%.
Does anyone have any idea of what's going on?
(As part as : sent it back for warranty ;D )
« Reply #3 on: April 23, 2021, 08:01:05 pm »
Mhhhhhh I've put a DC signal, and I can trigger glitches by moving the references and/or the dc offset.
It seems to be a memory problem inside the ASIC :
- It does appear on segmented memory, but only once
- When at very low sample rate, it happen one time every two acquisition
- Only affect CH1 et CH2, but never at the same time
... But I can't figure out why it does not happen every time at the same place for every tension values.
It's under warranty so I guess there will be no problem and I won't even think about repairing myself, but it's a real hard problem and I kind like that.
Well, the thing the more valuable for the planet (and Keysight btw) should be "Keysight sending me only the ASIC part", as it's a tiny board inside it, but I think it will never happen  :-DD
Online tv84
  • Country: pt
« Reply #4 on: April 23, 2021, 08:10:24 pm »
v2.10 here.
« Reply #5 on: April 23, 2021, 08:27:00 pm »
« Reply #6 on: April 24, 2021, 08:58:19 am »
Nope, it seems to be hardware...
The only thing I do not explain, it's why this problem appear and disappear regarding of the voltage and/or position.
« Reply #7 on: May 11, 2021, 07:34:08 pm »
Just to let you know, Keysight support is good, but rather SLOW |O
I contacted my reseller on April 24.
I was contacted by KeysightCare on April 28.
I received the "ok we will send you another one" on May 10.
But then I am still waiting for them...
Is this normal? Have you ever been confronted with KeysightCare?
Maybe I'm out of luck... twice :-//
Offline Neganur
« Reply #8 on: May 11, 2021, 07:46:59 pm »
Did you initiate the communication with Keysight or was there a 3rd party in between? (You mentioned reseller)
I’ve had good experience so far, but I had the email of a local contact who was very responsive. The logistics can be a bit slow though.
« Reply #9 on: May 11, 2021, 07:56:52 pm »
I initiated communication with a third party... I think I should not next time...
Offline Keysight DanielBogdanoff
  • ALL THE SCOPES!
    • Keysight Scopes YouTube channel
« Reply #10 on: May 12, 2021, 05:11:50 am »
I definitely recommend going straight to our support line for a situation like this - cuts out the middleperson. Third parties just come to us anyways. Calling the line is also a good option, but the email / webform should be equally fast.
Feel free to PM me the ticket # and the name of the person you're working with and I can check in on it.
The following users thanked this post: bestel
