Mhhhhhh I've put a DC signal, and I can trigger glitches by moving the references and/or the dc offset.
It seems to be a memory problem inside the ASIC :
- It does appear on segmented memory, but only once
- When at very low sample rate, it happen one time every two acquisition
- Only affect CH1 et CH2, but never at the same time
... But I can't figure out why it does not happen every time at the same place for every tension values.
It's under warranty so I guess there will be no problem and I won't even think about repairing myself, but it's a real hard problem and I kind like that.
Well, the thing the more valuable for the planet (and Keysight btw) should be "Keysight sending me only the ASIC part", as it's a tiny board inside it, but I think it will never happen
