I get your point, and if I could get a 350MHz analog for this price I wouldn't hesitate. But why would I choose a 25MHz used analog over a 25MHz brand-new USB oscilloscope (apart from looking better )? The Owon seems to be better than the usual DSOs in this price range, and it seems to be pretty stable: youtube.com/watch?v=gGOZ9PCVV_A
(Could someone tell me how to disable the Youtube video insertion?... )
One thing:- A 25MHz Analog Oscilloscope is just that,no matter what the time/div setting.
DSOs reduce their sampling rate when they are trying to look at long time intervals (20ms or so),because they lack memory depth.
In DSOs of the DS 1054Z class & above,this is
not a problem,as the reduction is usually not enough to cause "aliasing",but with very old or
very cheap DSOs this is a real problem if you need to look at complex signals at such timebase settings.
A classic test,which we used to disconcert the Tek & HP reps back in the day,is to try to look at a PAL video signal at
field rate (50Hz).
This signal contains content up to 5MHz,which the early DSOs could not reproduce at long time/div settings due to their reduced sample rate at such settings .
Some of them even had trouble with video at
line rate (15.625 kHz),with the colour burst signal at 4.433MHz reproduced as a bit of a "wiggle",having no relationship to the correct burst shape.
The cheap DSOs have the same problem due to cost concerns.
I've seen screenshots proudly posted on the internet by someone showing off the performance of the latest "el cheapo" DSO,which exhibit this behaviour.
That said,no,I would not pay 80USD for either of the analog 'scopes you linked to---this equates to about $A111,which is about twice what I would pay for what are fairly unsophisticated instruments,lacking delayed timebase & other refinements.
If you could pick up a Tek,HP,or Philips with those facilities for 80USD,I would recommend you do so.
On the other hand if you are certain you will
never need to look at high frequency signals using a slow timebase speed,then go for the USB 'scope.
If you are not so sure,get an analog,or save up for a Rigol or Siglent bench DSO.
