I've been hunting around for a new scope since my tek 2213A went out of focus on me and I just have not had the time to fix it yet.
I've only ever used analog scopes, but I have a project coming up where I could really use a storage-type scope, as I will be sampling a magnetic field sensor as its response decays to zero following an abrupt shut-off of an externally applied field (Time Domain EM as used in geophysical exploration). Although these could be repetitive signals, they might only be on the order of 1 Hz (slow end of things, probably up to a 1kHz on faster). It certainly was tough to see the images on the 2213a with the phosphor decaying too quickly.
For this project bandwidth is not hugely limiting, as the fastest signals are likely to be 40 kHz or so. (except for the digital clocks and what not)
Another reason I would like a digital scope is so I can download the waveforms into my computer and look at them in a spreadsheet/graph. This way I can compare individual captures, and stacks and averages. Persistence is probably something I would like to have to compare each event.
I would really prefer a 4 channel as most of the time I seem to want that extra channel, especially when there is a set up with a preamp and two following amps.
This type of work is somewhat more than a hobby, as I would like to build these instruments to help me in my work (geology is what pays the bills). Originally I was simply going to get a 4 channel analog scope for cheap, but I'd like to save myself some time, something I value more these days with two young kids. Once I thought I would go digital I gave myself a 1k$ budget, but I am willing to go to 2k.
I don't mind used, provided I can easily transfer data to my computer
I see the GDS-3000 has been around for about 3 yrs or so, and I assume that is why the prices have come down to a
price of $1616 including the power supply and serial bus software (150MHz, 4 CH). Not sure I would ever use the power supply software, and I do have a 16-ch logic analyzer, so the serial decode software is marginally useful (perhaps on some older equipment that I have with strange voltages it might be good).
I do realize the 25kpts and 3000 waveforms/sec are on the low end.
I feel like I am spending a huge amount of time trying to choose an oscilloscope, when I should get one and get testing! Any thoughts?
