Author Topic: BNC adapters...  (Read 3183 times)
Offline alank2Topic starter
BNC adapters...
« on: August 14, 2013, 02:23:48 pm »
Hi Everyone,
I'm looking to get a toolkit of a few pass through BNC adapters I've seen mentioned here in threads.  A 50 ohm terminator, some attenuators, etc.  Where is a good place that has these at a reasonable price/value/quality level?
Thanks,
Alan
alm
  • Guest
Re: BNC adapters...
« Reply #1 on: August 14, 2013, 02:48:57 pm »
I would not call an attenuator or terminator an adapter. Mini-circuits have some reasonably priced attenuators. Feed-through terminators from the usual suspects like Pomona are expensive, I haven't found a cheap source yet. They occasionally turn up used on eBay. Not a whole lot that can go wrong unless someone overloaded it. Used Tek feed-through terminators (not the precision or 3W type) have better specs than new Pomona feed-through terminators (lower VSWR).
Re: BNC adapters...
« Reply #2 on: August 14, 2013, 02:54:15 pm »
alm you are totally right, they aren't adapters! :)
Offline Sigmoid
Re: BNC adapters...
« Reply #3 on: August 14, 2013, 03:24:28 pm »
On Mouser you can get 1W 50ohm terminators for peanuts ($2), I'm thinking of getting a bunch. According to spec they are good to 4Ghz. I don't think that I'd normally want to drive a function generator above 7VRMS, so I guess 1W should be kind of enough.
A tee costs maybe $4, so you have a feed-through terminator under $10.
« Last Edit: August 14, 2013, 03:28:12 pm by Sigmoid »
alm
  • Guest
Re: BNC adapters...
« Reply #4 on: August 14, 2013, 03:49:47 pm »
The performance of a tee + standard terminator is inferior to a real feed-through terminator, though. The terminator should be as close as possible to the input. Not necessarily a problem for relatively low frequency work, but I wouldn't use it for fast signals. There's a reason why real feed-through terminators are sold and bought.
Offline Sigmoid
Re: BNC adapters...
« Reply #5 on: August 14, 2013, 04:38:16 pm »
Where would you put the frequency threshold when the difference starts to become noticeable?
alm
  • Guest
Re: BNC adapters...
« Reply #6 on: August 14, 2013, 10:42:05 pm »
I would start worrying above 100 MHz or so. The Pomona feed-through adapter is specified up to 500 MHz, and the Tek one to 1 GHz. Note that a scope will still display signals somewhat beyond its bandwidth. A 100 MHz scope is -3 dB down at 100 MHz (30% attenuation), but may attenuate 200 MHz signals for example by 65%, so an additional attenuation of 200 MHz signals may still be noticeable.
One signal where I would expect it to make a difference is in the Jim Williams pulse generator. This pulse has a rise time of a few hundred ps, so will have a bandwidth in excess of 1 GHz.
