Author Topic: BM869S not reading correct voltage  (Read 875 times)
Vgkid, TomKatt and 2 Guests are viewing this topic.
Online J-R
Re: BM869S not reading correct voltage
« Reply #25 on: Today at 06:52:25 pm »
The BM869s is actually pretty well sealed.  There are gaskets/o-rings around the battery cover and the banana jacks, even the screw heads.  So I don't think humidity would impact it.
But you could still fully inspect the PCB under a microscope looking for any solder issues or corrosion, clean selector switch and jack contacts.
A side note is that each jack's BeepJack feature does not function if their respective fuse is blown, so double-check those.
What 9V batteries are you using?
Offline BeBuLamar
« Reply #26 on: Today at 07:23:17 pm »
Can you send it to manufacturer for repair at reasonable cost?
