Author Topic: Hameg R&S HMO scope licenses not available anymore  (Read 36146 times)
Offline MichalZ
Re: Hameg R&S HMO scope licenses not available anymore
« Reply #100 on: March 03, 2024, 08:52:54 am »
Thank you very much tv84, works great :D
Offline electr_peter
  • Country: lt
« Reply #101 on: March 03, 2024, 09:07:50 am »
I had to enter the keys i generated manually as i couldnt get the scope to see the " serialnumber.hlk" file i made . any ideas? what i did wrong
There is info on this thread on *.hlk file formating. Have you tried that?
Offline dannyUK66
« Reply #102 on: March 18, 2024, 08:37:31 pm »
Hi Everyone,
I recently obtained a HMS-X but unfortunately the tracking gen appears to be limited use and it also does not have the 3Ghz Bandwidth option.
 I see reading this thread that some have had success with generating Keys but this is far beyond me.
Is there anybody that would be wiling to help me as although I have contacted R&S I expect they will advise to buy another but as a hobbyist this is totally unrealistic for a nice to have piece of test gear.
Hope I'm not  :horse: lol
Danny
Offline Franz Zinn
« Reply #103 on: May 06, 2024, 10:47:50 am »
Anyone tried this with HMO2024. If so could you please share offsets. Apologies if I overlooked it in this thread.
regards
Offline atila82
  • Country: ba
« Reply #104 on: May 07, 2024, 06:03:53 pm »
Hello everyone, great topic thank you.  :-+
I would like someone to help me. has RTC 1002 serial number 102546. thanks in advance.   :phew:
Offline TRN
  • Country: pt
« Reply #105 on: May 15, 2024, 06:27:32 pm »
The RTC 1002 is manufactured by Rohde & Schwarz, and they utilize a different licensing scheme than Hameg.
First you will need to provide a memory dump from the firmware, which requires you to open the scope, and connect a HW debugger to the JTAG port.
Once you have dumped the memory, somebody from this forum might be able to assist you.
Also the the R&S serial numbers normally contain two alphanumeric digits at the end, so your serial number should look like 102546-xx
Regards
« Last Edit: May 16, 2024, 05:24:30 pm by TRN »
