Here's my BM235 compared with a few others including my old Fluke 97. Keep in mind, the UT181 has been modified a fair amount after I damaged it. The UT61E has also been modified. The EX540, well it too was modified to the point where I had last changed out the RMS converter. Then there is the UT90A which, while not modified, has been damaged more times than I care to count. Then there's the BM869s which I also damaged and repaired. The only untouched meter is the BM235!
