Author Topic: [Fixed] BM235 issue no Loz DC, Voltage, ohms and diode  (Read 2538 times)
Offline taitekiTopic starter
« on: November 30, 2017, 05:30:03 pm »
I buyed 1 year and a half a bm235
for the first time a the dmm have a dim lcd but i doncared about that because i can read with no problems.
but some weeks ago the DMM stop to work poperly, i suppossed to be a battery problems and buy some new battery, but the issue continue.
The dmm dont work in voltage LoZ,DC, ohms and diode.
1 Loz, i put a 9V battery with arround 8,3V and got this.
2 DC the same with the DC range.
3 the ohms start with 0L but after short the terminas always show 0000.0ohms
4 in diode always show 0.000v
some one have the same problem?
thanks and apologies for my english.
« Last Edit: November 30, 2017, 09:41:21 pm by taiteki »
Offline retiredcaps
Re: BM235 issue no Loz DC, Voltage, ohms and diode
« Reply #1 on: November 30, 2017, 07:40:42 pm »
Check the soldering on the inductor.  See
The following users thanked this post: taiteki
« Reply #2 on: November 30, 2017, 09:39:13 pm »
Thx retiredcaps  :clap:.
dont remenber that video!.
L3 disapeared.
i put a new ferrite bead and
 :-/O
 :-DMM
Offline retiredcaps
« Reply #3 on: November 30, 2017, 10:12:41 pm »
L3 disapeared.
I wonder if this L3 will be a long term problem?  You are the 3rd or 4th person to have this bad soldering problem.
BTW, for the LCD contrast Dave did a video too.
Offline retiredcaps
Re: [Fixed] BM235 issue no Loz DC, Voltage, ohms and diode
« Reply #4 on: November 30, 2017, 10:16:15 pm »
We are also finding out that on some older Fluke 17x series, the soldering on that inductor/ferrite bead has aslo degraded or shook loose due to abuse?  However, this is over several years, possibly one decade.
https://www.eevblog.com/forum/repair/fluke-179-repair/
https://www.eevblog.com/forum/repair/fluke-179-not-working/
https://www.eevblog.com/forum/repair/fluke-179-76688/
Offline retiredcaps
Offline joeqsmith
« Reply #6 on: December 01, 2017, 12:04:12 am »
Mine had a notch cut out I assume for this reason.
https://youtu.be/g3uYcHAumhA?t=436
« Reply #7 on: December 01, 2017, 06:32:16 pm »
Thxs for the links.
in the case of this DMM it was in a non climatized zone, 40ºC-45ºC in summer and 8ºC-20ºC winter (Seville-Spain).
Possibly it has been damaged for a long time, since I have only used it to measure current.
in the image of my dmm it seems that the ferrite bean broke apart.
