Author Topic: BM235 defective?  (Read 15743 times)
Offline Dr.JoeTopic starter
BM235 defective?
« on: May 20, 2016, 05:18:11 pm »
Hello all,
my name is Johannes, im 27 and im from Germany. I am an electronics hobbyist, and i mainly do "audio stuff".
I recently bought a BM235 from Dave, and after the german customs had it for about 2 weeks, i finally got hold of it.
The first thing i did was test it on some AAA batteries, but the voltage readout was all over the place (sub 1V, and constantly changing), so i measured some SMPS at 12 and 5V:
12V:
cheapie Voltcraft VC160: 12.3V
BM235: 10.06V  :o If i reverse the probes, it only displays 9.06V.  :-//
5V:
cheapie Voltcraft VC160: 4.88V
BM235: 2.84V, and 2.48V with the probes reversed.
After that, i emailed Dave and he suggested i measure some batteries:
9V battery:
cheapie DMM: 9.44V no matter which polarity
BM235 in VDC Mode:: 7.17V correct polarity, -6.30V reverse polarity
BM235 in AutoV LoZ Mode:: 7.6V  no matter which polarity
and then i gets weird: When i try to measure an AAA battery, its starts of at around 1,07V and continuously goes down to 0V. This takes about 3-4 seconds. If i then short the probes, it displays around -0,7V and again goes down to zero. the cheapie DMM tells me the battery is around 1,17V.
However, if i measure my line voltage, its pretty much spot on: 239.9V at 49.98Hz.
The Ohms range is completely broken. No matter what i put across the probes, or if i short them, the meter tells me its off-range, and displays 0.L. Same with the continuity tester.
The temperature range doesnt work either. it just says "---F" or "---C", both with the supplied k-type probe and another one.
I have not tested the A or mA/µA Ranges yet.
So, am I missing something here, or is my meter broken?
Thanks in advance,
Johannes
Edit: i did change the batteries, but that didn't solve it.
« Last Edit: May 20, 2016, 05:32:03 pm by Dr.Joe »
Offline thisguy
Re: BM235 defective?
« Reply #1 on: May 20, 2016, 05:32:25 pm »
Maybe obvious, but you didn't mention whether you put fresh batteries in it. Did you? Edit: (Oh, I see now that you did)
« Last Edit: May 20, 2016, 05:35:20 pm by thisguy »
Offline retiredcaps
« Reply #2 on: May 20, 2016, 05:39:28 pm »
Hmm, if you are willing to take apart the BM235, I suggest you measure some of the input protection components (MOVs, PTC, power resistor,etc).  All can be done in-circuit.  A MOV should measure infinite resistance.  A PTC should measure around 1k ohm.  The power resistor, it varies in different meters, is probably around 1k ohm.
I would also do a close visual inspection, and/or post pictures here, to see if anything is obviously bad like bad solder joints, blown components, etc.
I can't see Dave denying you warranty/exchange if you take it apart.
« Reply #3 on: May 20, 2016, 06:09:46 pm »
thank you for the replies,
@thisguy: Yes, i did change the batteries. twice  :-+
@retiredcaps: i did open it already, and did a visual inspection, but im no pro, so i attached a picture.
I just measured the input protection components, and they measure as follows (referencing Daves pic: https://www.flickr.com/photos/eevblog/24781245266/in/album-72157664100975342/)
R7 and the one directly above it: ~1kOhm
PTC1: 1.6kOhm
PTC2: .94kOhm
Alls the 3 blue MOVS measure infinite resistance.
The black long resistor on the Mainboard measures ~10MOhm.
Offline retiredcaps
« Reply #4 on: May 20, 2016, 10:47:57 pm »
PTC1: 1.6kOhm
PTC2: .94kOhm
All those measurements above look okay.
Can you also verify those pink resistors (5M ohm) in Dave's picture are both reading 5M ohm?
« Reply #5 on: May 21, 2016, 11:22:22 am »
5.04/5.03 MOhm
Online EEVblog
« Reply #6 on: May 21, 2016, 11:35:13 am »
I've got another meter on the way back with similar symptoms. Really hard to diagnose these things without having the meter to hand.
I hope it's the same issue/cause as yours then we'd have something to go back to the manufacturer with.
I don't have a schematic which makes it harder.
Offline timgiles
  • Programmer, DB architect
« Reply #7 on: May 21, 2016, 11:58:29 am »
Keep the faith DrJoe - Dave is on the case and it should not be too long before corrective action can be taken.
Its a great unit, I have been using mine for a couple of months now, its never missed a beat.
Offline retiredcaps
« Reply #8 on: May 28, 2016, 03:14:01 pm »
@Dr.Joe
See eevblog 884
Check for bad soldering around the same area (underneath the board).
Offline jitter
« Reply #9 on: May 28, 2016, 03:29:30 pm »
Bad soldering could be a cause but it could also be a defective inductor L3 as the investigation in that video revealed.
The thread on EEVblog #884 is here.
« Last Edit: May 28, 2016, 03:32:34 pm by jitter »
Offline John_ITIC
  • ITIC Protocol Analyzers
    • International Test Instruments Corporation
« Reply #10 on: May 28, 2016, 07:14:43 pm »
I suppose this explains why one would pay more for a "quality" meter such as Fluke or Agilent. The designs may be similar but they have to cut corners somewhere and often this results in "cheap" parts sourcing, which translates to problems like this one.
Pocket-Sized USB 2.0 LS/FS/HS Protocol Analyzer Model 1480A with OTG decoding.
Pocket-sized PCI Express 1.1 Protocol Analyzer Model 2500A. 2.5 Gbps with x1, x2 and x4 lane widths.
https://www.internationaltestinstruments.com
Offline jitter
« Reply #11 on: May 29, 2016, 05:16:23 am »
That could be part of why you pay more, but I suspect that the design of Fluke or Keysight stuff might get a little more attention to detail.  And let' s not forget that they will most likely also have a huge markup on the actual parts and labour value.
« Last Edit: May 29, 2016, 05:17:54 am by jitter »
Offline Lightages
  • Canadian po
« Reply #12 on: May 29, 2016, 12:20:08 pm »
Every company has glitches, big prices or not, good reputation or not. You can't judge anything based on one or two samples. For example:
https://www.eevblog.com/forum/testgear/agilent-u1272a-crappy-soldering/?nowap
« Reply #13 on: May 29, 2016, 02:40:20 pm »
@Dr.Joe
See eevblog 884
I did see it 5mins after uploading.  >:D
Guess what? My L3 Inductor was faulty too.
Sorry, i currently don't have a macro camera, but on my Multimeter, L3 wasn't as far gone as the one from Daves Video. The solder connection to the lower pad (the one closer to the bottom of the meter) was broken, and therefore it was open circuit. i resoldered the joint, and voila, it works perfectly.
thank you all for your suggestions.
Offline TheAmmoniacal
  • Country: no
« Reply #14 on: May 29, 2016, 02:43:37 pm »
Thanks for reminding me of this thread, I never got around to open my U1272A!
Offline retiredcaps
« Reply #15 on: May 29, 2016, 03:24:46 pm »
So my suggestion to check solder joints in an earlier post was applicable, but understandably difficult to do with that input board covering up some of the pcb.
I'm glad your meter is working again!  :-+
« Reply #16 on: May 30, 2016, 08:52:22 pm »
I guess i spoke too soon.
DC Volt Range is now working, and as far as i can tell spot on. The continuity tester is working as well.
however...
The Ohms Range is not working, and displays O.L all the time. The continuity tester is working fine, but displays O.L when there is continuity. Also the Diode Check is not working. As far as i can tell, all the other functions are working fine.
 :o
Edit: DC mV Range not working as well. Set up a quick voltage divider, (1M and 10k Resistor with 5V across both of them, probes across the 10k resistor).  DC V Range shows 0.050V, DC mV Range shows O.L
Given that Daves Multimeter worked fine on the mV range before and after he fixed it, i can assume i have another failure. Going to pull that input board.
Edit2: Forgive me if this question is stupid, but when measuring volts (and amps), the meter just has to measure the voltage that it sees across the input circuitry, and compare it to a reference. But for functions like measuring resistance, the diode check and the capacitance range, the meter does actually have to put a voltage across the component?
« Last Edit: May 30, 2016, 11:24:10 pm by Dr.Joe »
Offline rstofer
« Reply #17 on: May 30, 2016, 11:51:30 pm »
Yes, the meter puts a small voltage across the component.  It would need to be at least 0.7V to forward bias a diode and many meters can also forward bias an LED.  I use the LED function to find the anode of SMD diodes before I place them.
I measured the voltage on the BM235 Diode function as 3.25V and on the Ohms function as 1.7V.
Offline retiredcaps
« Reply #18 on: May 30, 2016, 11:59:32 pm »
If you are going to desolder the input board, post clear focused pictures.  In addition, please post pictures of the other side of the pcb.    You might as well carefully remove the range switch and check there as well.
Offline thisguy
« Reply #19 on: May 31, 2016, 12:10:00 am »
It might make sense to look really closely at L2 as well and check that it's not open. It seems very unlikely that a single meter would have two unrelated failures. As others have said and after examining my own bm235, I see how removing and reinserting the big fuse could put a lot of flex and stress on that part of the board.
« Last Edit: May 31, 2016, 12:12:50 am by thisguy »
« Reply #20 on: May 31, 2016, 12:35:04 am »
@retiredcaps: Will do when my girlfriend returns from holiday with my camera. I'm afraid smartphone pictures aren't good enough
@thisguy: both L2 and L3 are at 0 Ohms.
R25 looks a bit weird and i can't get a solid measurement for it. Jumps around a lot, but that could be my cheapie DMM. I will try to take a picture.
Edit: could the unstable measurement be because im measuring in circuit?
I did take some smartphone pictures, they're better than no pictures. R32 (next to the big 10megohm resistor) looks a lot like R25, but measures &stable at 49.8kOhms. L10 looks weird, but is at 0 ohms.
« Last Edit: May 31, 2016, 01:08:53 am by Dr.Joe »
Offline BurningTantalum
« Reply #21 on: May 31, 2016, 12:33:05 pm »
Why are you doing all this dismantling and repair work on a brand new product?
BT
The following users thanked this post: totalnoob
Offline Kean
    • Kean Electronics
« Reply #22 on: May 31, 2016, 12:40:01 pm »
BT
Huh?  Do you know where you are right now??   :-DD
« Reply #23 on: May 31, 2016, 01:23:54 pm »
BT
1. Shipping costs (i'm in germany ;))
2. If i send the Unit back for repair, first i have to go through a lenghty customs burocracy war so i dont have to pay a customs fee again when the repaired unit comes back.
Offline rch
  • Country: wales
« Reply #24 on: May 31, 2016, 03:23:56 pm »
I bought mine at least partly to support Dave (although it is nice for once to own a meter I can safely check things in the mains distribution board with).   In the exceedingly unlikely event it fails I won't rush to send it back, unless perhaps it's BER because of an intrinsic fault.
