Reviving again. I ended up sending my DSO81304B to an expert in Infiniium scopes. I have been working with him for a while, and we are still tackling the display and option issues.
A few takeaways I have learned from working with these scopes so far (and Agilent/KS gear in general).
- Each product line (scopes, spectrum analyzers, signal generators, network analyzers) is made by totally different teams at Agilent/KS. This is why all the naming conventions are different, software suites are mixed, and things like licensing and service are also stratified.
- DSO80K units have two motherboard versions, Intel D915GUX and Adlink M880 Nitro. The D915GUX does not have on-board LVDS driver, so it uses an Adlink PCI-E card which communicates with the D915GUX chipset using intel ADD2 protocol. The PCI-E card converts ADD2 to LVDS for internal display and also controls the backlight inverter. M880 nitro is a custom board by Adlink which includes LVDS driver on board, so no card is needed.
I also bought a DSO80604B recently which has the D915GUX mobo and is fully working. To try and recover the 81304B display issues, I copied U4 EEPROM from the Adlink PCI-E display card in the working unit. To be determined if this fixes display issues.
See attached bin/hex files for U4 eeprom contents from working unit display card. Maybe this will help someone someday.
