Author Topic: Tektronix MSO2024B teardown  (Read 2378 times)
Offline kilohercasTopic starter
  • Engineer
« on: July 15, 2014, 03:29:54 pm »
Offline AndyC_772
Re: Tektronix MSO2024B teardown
« Reply #1 on: July 15, 2014, 04:47:41 pm »
I was really surprised to see that MPC870 processor, it's a dinosaur!
PowerPC core, 133 MHz core / 66 MHz SDRAM memory (no DDR capability), and the internal peripheral set is designed for networking and communications. If you wanted to build a product with a couple of 10/100M Ethernet ports and an RS232 interface ten years ago then it was a good choice at the time, but I'm amazed to see it in a relatively new design.
  • Engineer
« Reply #2 on: July 15, 2014, 05:23:39 pm »
Well, MSOX2000 is much better choice, but MSO2024B have some advantages, major will be easy application module hack, with 0.50$ EEPROM
