Author Topic: BK2190E Oscilloscope Stay in the on screen.  (Read 3285 times)
Offline E_SosaTopic starter
  • Country: mx
« on: September 08, 2022, 11:53:21 pm »
Hello Everybody
I work in a school and we have 3 BK2190 oscilloscopes that stay stuck in the on-screen. Is there a way to update the firmware or apply an hardware reset?
I found this post https://www.eevblog.com/forum/repair/bk-precision-2190e-stuck-in-boot-screen/msg3647065/#msg3647065
but it doesn´t work for me.
Can somebody help me please?
Offline tautech
Re: BK2190E Oscilloscope Stay in the on screen.
« Reply #1 on: September 09, 2022, 12:54:07 am »
Hello Everybody
Only with the recovery package listed in that thread.
Read, understand and follow the PDF instructions exactly.
2190E is a SDS1102CNL+ but at glance the BK recovery package appears identical to the CNL+ one from Siglent.
Getting the USB stick configured correctly and it being 8GB or smaller is of highest importance for the recovery process to work.
Try several 8GB or smaller USB sticks until you find the one that works. Those with an activity LED are most useful to see the files are being transferred over.
There is also this:
https://siglentna.com/operating-tip/oscilloscope-hardware-reset/
The following users thanked this post: Fungus
  • Country: mx
« Reply #2 on: September 09, 2022, 10:34:32 pm »
Thanks for your reply.
I have formatted the usb in FAT32 mode and pasted the 3 files in the root, my usb is 1GB but hasn't LED. I'll try with another one.
  • Country: mx
« Reply #3 on: September 09, 2022, 11:26:03 pm »
Bad news!
The USB doesn't turn the LED on.
I think the oscilloscopes are beyond repair!
Offline tautech
« Reply #4 on: September 10, 2022, 12:18:40 am »
Bad news!
Maybe not, we have some other tools.
When I have some spare time I can contact you to get your email and we'll try another line of attack !
Offline dtex
« Reply #5 on: September 22, 2022, 07:11:17 pm »
Hello. I've got two 2190e scopes that have this same issue as E_Sosa posted above. I've tried the USB drive with the recovery_by_USB_driver files, and have also tried the method of pressing MATH repeatedly upon power up, both to no avail. If any of you have other tips, I would be excited to hear them. Thanks!
Offline tautech
« Reply #6 on: September 22, 2022, 09:16:12 pm »
Welcome to the forum.
The USB stick and how it's configured is the key to success.
It must be max 8GB, formatted in FAT32 4k clusters and suitable for bootable application.
The recovery files must also be in the root of the drive.
Multiple attempts are sometimes required as is using a different USB stick.
Offline dtex
« Reply #7 on: September 27, 2022, 07:23:58 pm »
Thanks tautech. I'll give a few more usb sticks a try. I've tried two so far to no avail, both 8GB, both formatted to be FAT32 and both with the recovery files in the root of the USB stick. I've got a few more sticks I can try.
Offline tautech
« Reply #8 on: September 27, 2022, 07:27:04 pm »
Ideally you want a stick with an activity LED to see the files being transferred over then give it some time to rebuild the OS before it can continue on to boot.
It should be quick but not instant so give it time to do its thing.
Offline dtex
« Reply #9 on: October 27, 2022, 05:48:20 pm »
Life got busy so it took me a while to get back to this. Trying several different USB sticks helped. After trying several USB stickss (all <8GB) I found an old 256MB stick and that finally worked... for one of my two frozen scopes. The other scope does not respond in any way to the recovery USB stick in that the USB stick shows no activity at all when plugged in. I'm going to try the USB-B on the rear of the oscilloscope once I receive a USB-A to USB-B adapter. Will report back after that's done.
Thanks for the suggestions!
Offline tautech
« Reply #10 on: October 28, 2022, 01:37:00 am »
Good, you got one working.  :-+
Is there any chance the other is older and was running on an older firmware version ?
We may need to use a different recovery process.
Offline slbender
« Reply #11 on: October 28, 2022, 08:41:30 pm »
Slightly off topic, but might be useful.  I have a B&K 2190 completely different earlier unit, but the soldering was so bad - one channel blew a dual mosfet at the input.  Also some of the board interconnector’s pins pulled right out of the board connectors - probably this set escaped being inspected before it was packed in the box.
Steven
« Last Edit: October 28, 2022, 08:46:34 pm by slbender »
Offline dtex
« Reply #12 on: November 04, 2022, 07:41:15 pm »
It is possible that one has older firmware than the other. I purchased two batches of these oscilloscopes, separated by about a year. I don't know which batch each of these oscilloscopes came from.
What would this different recovery process entail? Is there any harm to trying it?
Offline tautech
« Reply #13 on: November 04, 2022, 07:44:43 pm »
Opening it. No harm at all but the process is more complex.
Continue with email.
Offline dtex
« Reply #14 on: November 04, 2022, 08:30:35 pm »
PM sent with contact info. Thanks!
Offline arnoudvh
« Reply #15 on: September 29, 2023, 04:40:10 pm »
The reset worked for me! Great! Of course... after I disassembled the whole scope to check all wire connections, etc... (hw guy...)  :P
I guess I should update the firmware - or is that going to risk another boot-up hang?
Offline tautech
« Reply #16 on: September 29, 2023, 06:29:20 pm »
FW updates never brick scopes.
If you used the latest USB recovery method you should already have the latest FW version installed, V6.01.01.25
Offline arnoudvh
« Reply #17 on: September 29, 2023, 09:30:29 pm »
I actually have the BK 2190D - where can I find the latest firmware for that? I have 5.01.02.22R5.
Thx!!
Offline tautech
« Reply #18 on: September 29, 2023, 11:27:48 pm »
Thx!!
BK would be your first port of call.
Offline arnoudvh
« Reply #19 on: September 30, 2023, 03:38:54 am »
I forgot to mention that the BK site doesn't list Firmware - neither for D or E model - links:
https://www.bkprecision.com/products/discontinued/2190d
https://www.bkprecision.com/products/oscilloscopes/2190E
Kind of strange.
But I saw you mention (in this post: https://www.eevblog.com/forum/testgear/bk2190e-stay-in-the-on-screen/msg4406332/#msg4406332:~:text=Siglent%20Distributor%20NZ.-,Re%3A%20BK2190E%20Oscilloscope%20Stay%20in%20the%20on%20screen.,-%C2%AB%20Reply%20%231)
that:
"2190E is a SDS1102CNL+ but at glance the BK recovery package appears identical to the CNL+ one from Siglent."
So I was wondering if anybody knows if there is also a package at for the BK 2190D in there: https://siglentna.com/service-and-support/firmware-software/digital-oscilloscopes/
Thanks!
Offline tautech
« Reply #20 on: September 30, 2023, 07:10:56 am »
BK D model has 40kPts mem depth which makes it equivalent to older CNL models (without LAN) for which there is no recent firmware.
The following users thanked this post: arnoudvh
Offline arnoudvh
« Reply #21 on: May 15, 2024, 01:00:48 pm »
Repeatedly pushing the MATH button during power-up worked for me (after a few tries).
Offline cujo31
« Reply #22 on: June 23, 2024, 11:48:51 pm »
I also have this issue with my 2190E. The Math button method didn't work for me. I have also tried several different USB drives ranging from 512MB - 8GB, but the USB port doesn't appear to have power. Tautech, if you have any other tricks up your sleeve, I'd appreciate the help.
Offline tautech
« Reply #23 on: June 24, 2024, 06:34:55 am »
Check your messages.
