I recently decided to experiment with Python so that I can use it for future projects. The best way to learn was to try doing something with it, so I've decided to write a simple program to control the BK 8500 electronic load.
The program is fairly simple but includes what I though would be useful to me.
I've placed the windows executable as well as the python source files along with additional information (all of which is also included as a readme file accompanying the source files) on my blog:
https://tolisdiy.com/2021/03/16/control-program-for-bk-precision-8500-dc-electronic-load/I'm attaching the source files to this post, the executable itself is too large to add as an attachment, but can be downloaded from the blog page linked above.
A direct link to the file:
https://tolisdiy.com/wp-content/uploads/2021/03/bk8500_controller.zipFeel free to use the program as a whole or the bk8500.py module on its own. Hopefully it will be useful for someone else too
Edit March 25, 2021:V1p1 is now available for download from the blog page link above (v1.1 source files are added to this post too).
The change log for this version:
– I/V/P readings have trailing zeros even if current value can be represented with low number of digits. If instrument is at higher range, last digit will be ‘0’ at all times
– Added measurements (I/V/P) logging. Logging starts when instrument is connected, and ends automatically when its disconnected. New connection will overwrite log file. Log file named “readings_log.txt” placed in same library as the run file
– Added plot of V/I history in a new tab (“Plot”)
– Added right click menu to V/I plot to clear history (plot and readings log file) and to save plot to snapshot
