Author Topic: what is the most common durometer for soft equipment features?  (Read 7344 times)
Offline coppercone2Topic starter
Has anyone measured the durometer of something like a fluke multimeter/scopemeter case or a HP bump guard (rubber bezel on the half rack instruments) or something along those lines?
Offline timeandfrequency
Re: what is the most common durometer for soft equipment features?
« Reply #1 on: February 04, 2024, 01:24:03 am »
Hi coppercone2,
Here are the hardness values I could measure :
- HP/Agilent rubber bezel : ShoreA 85
- Fluke Scopemeter (top & bottom yellow parts) : ShoreA 90
This should give you a ballpark if you expect to 3Dprint rubber protections for T&M enclosures.
The following users thanked this post: Kean, the Chris
« Reply #2 on: February 04, 2024, 01:37:02 am »
oh wow that is alot higher then I thought
If I had to guess I thought it would be around 70. That seems way too soft if I know those guards are 85-90
« Last Edit: February 04, 2024, 01:38:36 am by coppercone2 »
« Reply #3 on: February 04, 2024, 02:28:30 am »
I also thought it was a bit softer.
Old rubber tends to get harder over time.
However you don't want your T&M equipement to act like a super bouncing ball.
A TPU85A filament should be a good start.
« Last Edit: February 04, 2024, 02:30:25 am by timeandfrequency »
« Reply #4 on: February 04, 2024, 02:45:56 am »
nah I wanted to make molds and cast it I don't like those filament printers one bit
