As stated above in an edited post, The DMM would be used for calibration/verification of the cheaper equipment I have, because right now, I own a Tenma 72-10495 and two AN8008s.
As for the requirements:
I have a budget of 3500CZK or around 150€
It has to be available in my country, which means Farnell is a safe bet, although I might be able to find different distributors as well with some digging.
I need it to be as accurate as I can get, preferably under 0.5% on all ranges
It needs to have small long term drift, as I don't have a reference to calibrate against
Auto-ranging with manual override that's pretty fast
Latching continuity function
capacitance measurement function is nice, but not essential
I don't need a temp measurement function, but it wouldn't hurt to have it
I'd like it to have good input jacks, because I've had to toss a few multimeters because of faulty jacks, and I'd like to avoid that.
It has to be reasonably safe, I don't know what that requires aside from HRC fuses.
Access doors for the fuses and batteries would be real good
I'd like something with over 10000 counts for the increase in accuracy
If possible over 20A max current measurement, the voltage is not that important, but it has to handle mains (230VAC)
That's pretty much it. I'm mostly going off of Dave's reccomendations from his multimeter buying guide, and my preferences.
Again, I'm not that well versed in buying multimeters, so my requirements might be way to high for the price.
