All, I got a BK 2540B-GEN, startup with blank screen, cost 30 bucks. The seller said no repair for it. It's a BW 60MHz with 1GSa/s, plus a 20MHz arbitrary wave generator. As it's body appearance is good, and price is so low, I bought it. Will reach to me in 2 days.
Blank screen, so the power maybe OK, but need to check. Then possible problem could be the CPU reset circuit, or a bad crystal? Will check by this sequence when received it.
Searched the internet, can only find the user manual, no service manual.
The BW is a bit lower. There is a BK2542B-GEN with 100MHz BW and 40MHz wave generator. I guess there should be a way to do a BW upgrade for BK2540B-GEN, but didn't find any clue on the net. Very appreciate if you know something about this and can share here. Thanks in advance.
