Author Topic: Tek 2215 - Never been used!  (Read 4290 times)
Offline TheBayTopic starter
  • Country: wales
« on: September 14, 2018, 07:08:37 pm »
Friend popped over with a gift for me, his dad was going to throw out a Tek 2215 so he thought I'd like it.
I know there is not much love for this scope on the forum, but it doesn't seem a bad little CRO. And I couldn't let him throw it out!
The interesting thing about this scope is, it has never been used! It's a British Telecom badged unit and has the original "Post Office (PO)" branded mains plug.
This particular scope was manufactured in 1983 was never used and has just sat in storage since!
The manuals and 10:1 P6120 probes were still sealed in their packaging, the CRT is lovely and bright, also very crisp but hard to see on this picture as my phone won't focus on the CRT.
Am I right in thinking there is no graticule illumination on this model?
« Last Edit: September 14, 2018, 07:12:08 pm by TheBay »
Re: Tek 2215 - Never been used!
« Reply #1 on: September 14, 2018, 08:12:33 pm »
I don't think so because if there was then the control would surely be on the front panel and I can see nothing relating to screen illumination on it.
It is however a really nice looking scope and must a find in a million, never being used in all this time.
Offline particleman
« Reply #2 on: September 14, 2018, 11:05:00 pm »
If you want to make sure the CRT stays nice and bright make sure sup3010 has been done.
The following users thanked this post: TheBay
Offline drussell
  • Hardcore Geek
« Reply #3 on: September 14, 2018, 11:15:12 pm »
SUP3010 instructions attached.
Offline bsfeechannel
« Reply #4 on: September 14, 2018, 11:40:07 pm »
What's so dreadful about this scope to attract so little love?
  • Country: wales
« Reply #5 on: September 14, 2018, 11:45:30 pm »
Thanks both, will check this!
It's not really a great scope for Tek, not up to their usual standards. I quite like it though having played with it for a bit.
Some can be problematic as they are an early SMPS based scope from memory.
Offline drussell
  • Hardcore Geek
« Reply #6 on: September 14, 2018, 11:51:53 pm »
Mostly just because it was a lower-cost, more basic scope than what most people think of when they see a Tektronix scope.  When most people think of a Tek scope, you would generally think of a state-of-the-art (for the particular time), high-end, feature-rich and expensive unit.  :)
  • Country: wales
« Reply #7 on: September 15, 2018, 12:16:40 am »
Do any Tek aficionados know what "Mod WU" means on my scope? It's stamped on a plate below the serial number.
Offline Old Printer
« Reply #8 on: September 15, 2018, 12:27:22 am »
Might want to have a look at the caps, particularly in the power supply.
Offline tautech
« Reply #9 on: September 15, 2018, 01:22:46 am »
Some reading for ya:
https://www.eevblog.com/forum/repair/tektronix-2215-scope-repair/
Yep the SMPS can be tricky to fix and even get your head around but threads like these offer good guidance.  :)
Offline drussell
  • Hardcore Geek
« Reply #10 on: September 15, 2018, 01:42:16 am »
Yeah, aren't there several different versions of the power supply?  I think the service manual has a bunch of info.  You should be able to get the most recent revision from Tek's website, I would assume.
Also, depending on the age of your unit, there were some "improvements" called Option 48 (which is funny because I don't think Tek ever officially offered any "options.")
I was going to attach document 045-0034-00, but it is 0.99 MB, a few bytes too big for the forum, but here is a link...  :)
http://hakanh.com/dl/docs/kitinstructions/045-0034-00.pdf
Offline Per Hansson
« Reply #11 on: September 16, 2018, 10:03:53 am »
Really nice find!
From my service manual about option 48:
"All instruments manufactured in Europe contain the Pre- regulator board (A18). These instruments have serial numbers 200000 and up."
Also the serial number on this unit is high enough that SUP3010 should have been done from the factory too, but do look at the scope to verify that.
It should be marked with M50226 behind the rear panel.
  • Country: wales
« Reply #12 on: September 16, 2018, 12:04:48 pm »
Stripped her down for an internal inspection, wow it really is like new inside!
Checked for the modification and it has been carried out (The transformer has a 01 sticker)
Everything looks lovely inside, one thing I did notice is that the CRT has an orange graticule scale underneath the lens, there is also a space on the scope for a lamp.
I might retrofit a white LED or a lamp in there to illuminate the scale.
Pics:
« Last Edit: September 16, 2018, 12:44:01 pm by TheBay »
« Reply #13 on: September 16, 2018, 05:57:44 pm »
Do not use a white LED, use an orange LED instead, 3mm, 2 in series each side turned to light the glass of the CRT. Much better illumination and a much better contrast with the blue white of the CRT, plus the LED's do not leave a flood of activated phosphor on the CRT at high brightness.  Then you can use any convenient power rail around 12V that has 20mA of current capacity, and a 10k variable resistor across the 12v rail, feeding the base of a NPN transistor (PN2222A) via a 1k resistor, and collector to 12V, and a 1k 0.5W resistor from emitter to the 4 LED's in series. Gives a good brightness range from off to way too bright.
I did the same for a USB light, though it spent most of the time running at 1mA, as the full 20mA of current through the recycled white backlight LED's I used ( amazing how bright those suckers are these days at 20mA, when they run in the panel at 50-100mA) was basically daylight.
  • Country: wales
« Reply #14 on: September 16, 2018, 08:53:23 pm »
Great idea! I did wonder if a white LED would cause phosphor glow, my HP1741A is quite strange when you turn off the light as it almost glows in the dark due to the persistence type CRT.
I'll play around with some Amber LED's, I can hide the pot behind the CRT lens bezel, I don't really want to drill holes in this.
« Reply #15 on: September 16, 2018, 09:00:28 pm »
Good idea with the pot behind the crt trim, there are some ready made holes that you can use  :-+
  • Country: wales
« Reply #16 on: September 16, 2018, 09:23:01 pm »
That's the idea :)
I'm almost certain those holes/slot take the Tek graticule lamp assembly.
« Last Edit: September 16, 2018, 09:28:21 pm by TheBay »
Offline Per Hansson
« Reply #17 on: October 01, 2018, 07:23:38 pm »
Pics:
Yea it really looks pristine!
One thing to keep in mind is this from the service manual addendum at the end saying this:
To reinstall the Preregulator board, perform the following steps:
NOTE Check for sufficient silicon grease and proper positioning of the insulator in the plastic holder housing Q933.
  • Country: wales
« Reply #18 on: October 01, 2018, 08:03:37 pm »
Pics:
Thank you, will check that out and apply fresh grease.
Offline boffin
« Reply #19 on: October 01, 2018, 09:10:00 pm »
And frankly red looks cooler too.
Offline Per Hansson
« Reply #20 on: October 02, 2018, 07:50:32 pm »
Your welcome :)
Also please be sure to use non-conductive grease.
If the MOSFET makes contact with the chassis it would be live.
That's what the white spacer is for...
Offline David Hess
  • DavidH
« Reply #21 on: October 03, 2018, 01:58:47 pm »
Only the higher end and later 22xx models included graticule illumination.
The 2213 and 2215 were essentially prototypes of the 2235 series and because they had some problems, were quickly replaced by the 2213A and 2215A.
