Author Topic: New (?) Rigol scopes (DS2102E and DS2202E)  (Read 3622 times)
Offline Gabri74Topic starter
« on: September 21, 2017, 06:00:33 pm »
Just received an email from TEquipment about two new (?) rigol scopes (see screenshoots attached).
647$ for the 100MHz version, 847$ for the 200Mhz version.
Copy pasted from the email:
  • 1GSa/sec on all channels provides full 5X oversampling all the time
  • Free Serial Decode/Trigger supports most of today's common standards
  • 28M Record Length on all channels enables long captures to find elusive problems
  • Vibrant 8 Inch Intensity Graded Display provides easy observation and analysis
  • Waveform Record/Capture, Advanced Math, and 17 trigger types
Free decoders...It seems that Siglent has shaked a little bit the market  :-)
Offline thm_w
  • Non-expert
Re: New (?) Rigol scopes (DS2102E and DS2202E)
« Reply #2 on: September 21, 2017, 11:24:47 pm »
The specs are identical to the DS2000A, so it seems they have only added the free decoders and changed the Rigol logo yellow to blue.
I guess it makes sense to create a new part number to avoid confusion with the old one.
Offline H.O
« Reply #3 on: September 22, 2017, 04:56:42 am »
> The specs are identical to the DS2000A...
Not quite. In dual channel mode they're similar (or perhaps even identical) but in single channel mode the A-model is a bit different.
In dual channel mode they both sample at 1GSa/s but in single channel mode the DS2000A can sample at 2GSa/s. Both mopdels can get you 28Mpts per channel in dual channel mode while only the A-model can give you 56Mpts in single channel mode.
There's another thread on the subject: https://www.eevblog.com/forum/testgear/rigol-ds2000e/
« Reply #4 on: September 22, 2017, 07:27:48 am »
Ops, missed it, sorry for double posting on the same subject.
