Yes, its correctly recognizing both as Venus (Skytraq) receivers correctly.
This is the firmware revision from my s1315F Which is an approximately 2012 Venus 6 also flash based Skytraq chip with raw data output. Very accurate GPS-only- No Glonass or Galileo.
# <name>Venus receiver</name>
# Unit type: Venus GPS receiver
# Kernel: 0001.04.110
# ODM: Ver: 0001.08.23
# Rev: Rev: 0011.05.12
So, trying a /tsx value of "500" now my ntp-set system clock and the Heather clock display appear to be changing approximately at a similar time but I am still getting the "No UTC OFFSET" alert and the main clock is still displaying in yellow.
Under "operation mode" it says PPS OFF.. and Normal and under that it says "No status avail"
Its tracking 9 satellites or more and the position fix seems accurate enough except that the altitude seems to be truncating the altitude to the nearest meter, also altitude seems off by a significant amount, however the amount keeps changing (?) why - maybe has to do with "geoide" its using?
Quote from: texaspyro on Today at 18:22:01
