Lady Heather version 5.0 is now available for download from:
http://www.ke5fx.com/heather/readme.htmMany thanks to John Miles for hosting the distribution and his work on the Windows installer, PDF documentation file, readme file, and bring an all-around good guy.
Heather now has some proper user documentation. Check the heather.pdf file and/or the comments in the first 3500+ lines of the heather.cpp file. Heather can be compiled for Linux (including the Raspberry Pi) and macOS. Download the heatherx11.zip file and check the readme.txt file for compilation instructions.
There are MANY new features in Heather. One of the main ones is support for many new receiver types. When Heather is started it defaults to attempting to automatically determine the receiver type. You can bypass this and force the receiver type using the new "/rx..." command line options. Some receiver types cannot be auto-detected. Also many receivers power up speaking NMEA and you can enable their native binary language using the /rx commands. Native binary mode gives better information and allows controlling the receiver configuration and settings.
Currently-supported receivers include:
Trimble Thunderbolt and Thunderbolt-E
Acron Zeit WWVB receiver
UCCM - Trimble / Symmetricom GPSDOs
DATUM STARLOC II GPSDO
NEC GPSDO (STAR-4 compatible)
GPSD interface
Jupiter-T (aka Zodiac)
Lucent KS24361 REF0/Z3811A (19200:8:N:1)
Motorola binary format
Generic NMEA receiver
Trimble Resolution T family with odd parity
Sirf binary
Generic Trimble TSIP binary
Ublox UBX binary
Venus mixed binary / NMEA
Nortel SCPI-compatible GPSDOs (NTWB, NTPX, etc.)
Z3801A and compatible SCPI GPSDOs
HP 5xxxx-style SCPI
Oscilloquartz STAR-4 (via the management interface)
NVS binary
PC system clock (no receiver)
After installing Heather, you should edit the heather.cfg file (or the PROPERTIES setting for the desktop icon) for your desired configuration. Everybody should change the "/tz" option for their time zone... it comes set up for the US central time zone. International uses should add a "/b..." command to set their daylight savings time information. On Windows, you can press the "n" key and that will bring up NOTEPAD to edit the file. For the changes to take effect you will need to re-start Heather (or do a "r heather.cfg" keyboard command).
