Quote from: hpw on January 09, 2021, 09:39:17 pmQuote from: tautech on January 09, 2021, 08:15:20 pmQuote from: hpw on January 09, 2021, 04:34:43 pmalso a pointer for the 16 port logic graph's, while would like to analyze propagation timing & delays.What do you mean by this ? I have the Siglent STB3 test board and it can generate a wide range of signals so maybe there's some LA vs analog signal measurement you would like to see.OK, if you have a ADC/DAC with various clocks & timing & various additional signals who relate to the master clock, I would like to measure & see how the edges are within the spec's. So within the graph, I would like to measure the delay/time or when the edge happen.Hope it is now clear enough... a picture would be anyway better Some digital channels ( 8 ) with 3 active signals with Ch4 connected to D0 showing skew between digital and analog signal paths. Triggering in ch4 with a zone trigger (off display) and digital decode engaged just for fun. X cursors on D0 and trigger point of Ch4 displaying 3.9ns propagation delay. Zoom mode used.Now.....This is a SDS5054X but I would entirely expect SDS2000X Plus to produce exactly the same result as their firmwares are closely aligned.Hopefully I collect more SDS2000X Plus tomorrow.
