Author Topic: Agilent 33410A Noisy Fan or Normal?  (Read 1739 times)
Offline K1JOSTopic starter
« on: January 18, 2014, 09:36:22 pm »
I just got a used 33410A and so far it seems to work perfectly and in excellent shape.  However, the fan appears much noisier than I expected sounding almost like the noise one hears from a drafty window on a windy day.  More troubling than the noise is the varying pitch of the low-pitched whistling exhaust making me worried about a power supply stability problem.  I have not disassembled it yet as I ahve a right to return it.  The meter is spotless without dirt/dust apparent.  Apart from opening it up and checking the fan voltage for stability , any other advice would be appreciated.
Jerry
Offline Noise Floor
Re: Agilent 33410A Noisy Fan or Normal?
« Reply #1 on: January 18, 2014, 11:14:09 pm »
What's the build date?  You mention you have the right to return it, is it from a used/rental retailer?  If so, see if you can listen to an identical model and see if it sounds the same.
« Reply #2 on: January 18, 2014, 11:20:32 pm »
It was a remote purchase - i live in the sticks :-)
jerry
