I got recently this little bench power supply and l like it a lot so I thought I should share.
This is the Tenma 72-8350A which the 20V/5A version of the power supply Mike reviewed here
https://www.eevblog.com/forum/reviews/tenma-72-8345-bench-psu-review/This is an upgraded model (hence the 'A') suffix and the original version seems to be discontinued. The display is now white on black with excellent contrast, it shows the current limit setting without having to short the output and a click or two on the voltage and current button gets you into one of two course adjustment modes. Internally it looks just the same as in Mike's review.
Fro reference, I tried the Korad KA3005D and didn't like it. Bulky, complex panel, and once every few times I turned it on the top cover made a loud sudden noise, probably from magnetic field change in the transformer below it.
Like:
* Compact, light, small footprint
* Large clear display
* 100W output (way more than I need, Mine is 20V 5A, they also have 60V 1.6A and 36V 3A versions.).
* Accurate voltage/current settings and readings.
* Simple and intuitive to operate.
* Output on/off switch (my HP E3610A doesn't have it).
* Good construction overall.
* Reasonable price (~$160).
Doesn't like:
* Can't set current limit below 150ma (I often goes down to 40ma limit when bringing up boards).
* No post binds. (I am using these
http://radioshacklb.com/index.php?route=product/product&product_id=2656 )
* Handle (removed).
* No UL certification.
Overall this power supply is a very good fit for my hobby needs. I think I will put my HP E3610A and Protek 303 for sell, and use only this one.
