Keithley 2000/2015 are nice high precision bench meters, the same is true for various other vintage gear from e.g. HP/Agilent, Solartron/Schlumberger, Datron. But none of them has a continuity test, which appears to be important for deanclaxton.
Fluke 45 has fast continuity, but even though just average in terms of resolution/accuracy it is still even more expensive than e.g. Fluke 8040A (at least in Europe).
The Keithley 2000 has a continuity test, as do many of the other usual suspects.
Interesting. I could have sworn that my 2015 THD doesn't have it. maybe Keithley have added this feature at some point?
But then again, I might have missed it, since I rather use my Fluke 45 and not the high prescision bench meters for continuity tests.
Can't check it right now, but will do it next weekend.
In case of my Fluke 8840/42 and Keithley 2001 meters I'm pretty sure though that they don't have continuity.
Btw, Nicos remark about the current ranges is worth emphasizing: not so much the high current ranges, but especially the lower ones are missing in most of these vintage instruments:
Schlumberger/Solartron 7150: 2A only (another one with no continuity)
Fluke 8840A: 2A only
Fluke 8842A: 2A plus a barely usable 200mA range
Keithley 2015 THD: 10mA, 100mA, 1A, 3A (same as HP/Agilent 34401A, resolution still just 10nA, no better than a halfway decent 4-1/2 digit handheld)
By contrast:
Keithley 2001: 200µA, 2mA, 20mA, 200mA, 2A (resolution 10pA!)
