@pdenisowski: It would be nice if you could also measure the 'Amazon' pre-amplifier to see how it stacks up.
Hi, a while ago I measured another Chinese preamp (see pictures attached) with an HP8970A & 346B noise source, and it did meet it spec quite reasonable.
Spec according to Ali-Express:
Gain: typical value 31dB-0.5G input output impedance: 50Ω
Maximum output power: P1db 11dBm-0.5G
Input signal: <0dBm (>0dBm input signal has been distortion)
Bandwidth: 50K-2GHZ (different gain in different frequency)
Noise coefficient: 2dB-0.5GAs I did not want to bother writing an application for the HP 8970A, I just used in XY plotting outputs. My picoscope does not have a blanking option, so the retrace is also visible.
Plot is from 0 to 1.6GHz (so 160MHz per division)
Bottom trace is the noise figure (1dB per division): noise figure stays below 2dB up to 1GHz, and never goes above 3dB.
Top trace is the gain (4dB per division): gain up to 800Mhz is fairly flat and around 32dB and drops to 25dB at 1600MHz.
For only 14€ including shipping, this is quite a useful amplifier.
I also have one based on a SPF5189 that looks like the one in the attached picture, when I have some time in the lab I will try to measure this one also.
