Author Topic: Battery Testing Instruments  (Read 1485 times)
Offline MasterBuilderTopic starter
« on: July 06, 2020, 10:01:00 am »
Let us take a look at battery test equipment. Ive been confused :-// by the various specifications and claims made by some of the vendors of Battery test equipment. Could someone elaborate on how and what these instruments might be measuring and calculating beyond simple Voltage measurements.
The Fluke application note says imporatant health indicators are Internal battery resistance (impedance) and Discharge testing
https://dam-assets.fluke.com/s3fs-public/6004018_0000_ENG_A_W.PDF
The keysight application note has plenty of good background information.
https://www.keysight.com/us/en/assets/7018-06734/application-notes/5952-4191.pdf
A few notable products:
ACT 612
Powered by the battery, Claims to simulate a 20 hour discharge in seconds, how? Is this a discharge test?
https://www.actmeters.com/products/battery-testing/act-612-6v12v-lead-acid-intelligent-battery-tester/
BK precision 600B
Powered by the battery, this displays remaining battery capacity, voltage and internal resistance test presumably.
https://www.bkprecision.com/products/electrical-battery-testers/600B-12v-sla-battery-capacity-analyzer-tester.html
BK precision 603B
This does everything the 600B does, also does a discharge (load) test.
https://www.bkprecision.com/products/electrical-battery-testers/603B-6v-12v-sla-battery-capacity-analyzer-recorder.html
Fluke 500 series
Measures voltage and resistance this seems to have internal battery resistance and discharge testing
https://www.fluke.com/en-ie/product/electrical-testing/battery-analyzers/fluke-500
BK precision BA6010
While significantly more expensive then the handheld BK precision battery testers there is no mention of discharge testing? This also has Kelvin measurement features.
https://www.bkprecision.com/products/electrical-battery-testers/BA6011-300-v-battery-analyzer.html
Amprobe BAT-500
The datasheet says it calculates life from battery internal resistance and Voltage, this seems to be clear enough.
https://www.amprobe.com/product/bat-500/
Re: Battery Testing Instruments
« Reply #1 on: July 06, 2020, 11:51:34 am »
Not been impressed by the ACT units I've used. For small lead acids these work well but you have to gather your own data set:
https://www.yuasa.co.uk/chargers-and-accesssories/testers-battery-analysers/show/all.html
For bigger ones, say 24Ah and up, these are what I prefer:
https://www.interparts.uk/durite-discharge-battery-tester---612v-275a-0-524-08-7294-p.asp
Thesedo get quite warm if you've a few batteries to test...
« Last Edit: July 06, 2020, 11:53:58 am by AVGresponding »
« Reply #2 on: July 06, 2020, 05:32:56 pm »
I notice the Yuasa testers you linked are described as Battery analyzers. What do they mean by analyzer, I expect it does a few measurements and then a calculation. So then, is it practical to do this on some test equipment that I might have lying around; I.e. measure Voltage with the multimeter, measure impedance with an LCR meter and do a little calculation fort the capacity/ health/ state of charge?
But this leads me to the question, are these battery testers/ analyzers just LCR meters with less features?
Regarding the discharge tester, how long would you discharge the battery for? Is it worthwhile discharging at high load for a few seconds and is this much better than the battery impedance test?
« Reply #3 on: July 06, 2020, 07:49:42 pm »
They measure the internal conductivity of the battery. Apparently it's a good measure of its health, at least as far as AGM types anyway.
I haven't been doing that job for some months now but iirc they read out in nS.
As for the idea you can simulate a 20 hour discharge "in seconds", I don't see how that can be possible.
Discharge profiles vary considerably based on load, and the internal heating that larger loads generate.
That's why datasheets for batteries show different real capacities based on discharge current, usually with lower discharge rates equating to larger capacity.
As far as I know, the only time higher current gives higher capacity is when you've a low ambient temperature and the self heating helps the chemical reaction get closer to optimal.
Offline jpyeron
    • PD Inc
« Reply #4 on: November 22, 2023, 11:10:06 pm »
I will reword this. Why should I spend more than 400$, when I can play, build, and learn. How do these devices work? How would one start to build one?
Offline Fungus
« Reply #5 on: November 23, 2023, 03:08:35 am »
ACT 612
It only does it for a very specific chemistry.
It probably places three or four different loads on it, measures voltage drop at each load, then extrapolates using tables.
