Author Topic: Rigol ds1000z WFM file reverse engineering  (Read 7780 times)
Offline preamp.org
    • preamp.org
Re: Rigol ds1000z WFM file reverse engineering
« Reply #25 on: May 15, 2024, 01:53:11 pm »
I am trying to convert the WFM files that get saved to a USB thumb drive, since I don't want to have a PC running alongside the scope. As far as I can tell right now, those files are missing some vital calibration data, though.
Regards,
Lasse
Online RoGeorge
« Reply #26 on: May 15, 2024, 02:48:48 pm »
Never used local saved files, my oscilloscope is always connected to LAN, and using a PC when data capture or screen capture is needed.  But if you have to save locally, there are many WFM readers already, first search result:
https://pypi.org/project/RigolWFM/
My guess is the waveform file format is something standard, like this:  https://download.tek.com/manual/Waveform-File-Format-Manual-077022011.pdf
Offline preamp.org
    • preamp.org
« Reply #27 on: May 15, 2024, 02:59:38 pm »
Have a closer look at your first search result: https://rigolwfm.readthedocs.io/en/latest/1-DS1000Z-Waveforms.html
Some quotes:
Honestly, the Rigol firmware for these scopes is a disaster
At least two other people (...) have tried to sort this out without apparent success.
The offset seems to be completely arbitrary. Consequently, if you want to use converted .wfm data, validate it against your own measurement first!
Like I already said in my first post in this thread, there seems to be something wrong with those WFM files of a couple of specific models, and there doesn't seem to be a working conversion tool out there - not even from Rigol themselves.
Regards,
Lasse
Offline Mechatrommer
  • Country: my
  • reassessing directives...
« Reply #28 on: May 15, 2024, 04:50:17 pm »
welcome to the club...
Offline preamp.org
    • preamp.org
« Reply #29 on: June 16, 2024, 09:01:10 am »
This is even worse than I ever deemed possible  :o. The data gets scaled differently depending on the sample rate, for the same signal on the same channel with all the other settings being the same. Why is that? Might be due to more noise on the highest sample rate, but I did not expect the difference in scale and offset to be higher than the noise level.  :-//
Regards,
Lasse
