Author Topic: IET DE-5000 LCR Meter in UK  (Read 45971 times)
Offline Srbel
  • Country: cs
  • Electronics engineer
Re: IET DE-5000 LCR Meter in UK
« Reply #75 on: November 06, 2015, 07:05:04 am »
I have DER EE. Version for Japanese market, so I got manual in Japanese.
This is the correct manual: http://akizukidenshi.com/download/ds/deree/DE-5000_manu_en2p.pdf
I have just received the unit few days ago, and I have only tried it out a bit. I have not had the time to read the manual in detail yet.
Offline Srbel
  • Country: cs
« Reply #76 on: November 07, 2015, 11:56:36 am »
No 1 milli Ohm resolution. :(
I only get 10 milli Ohm resolution on DCR.
I can not measure ESR on high frequencies (100 KHz, 10 KHz or even 1 KHz on some), if capacitor is more than a few hundred uF. :(
Offline kripton2035
« Reply #77 on: November 07, 2015, 12:08:00 pm »
measuring ESR at the milliohm is useless, unless you're doing RF stuff
in that case a professionnal LCR meter is required, but it will cost 10x the DEREE at least...
Offline PA4TIM
« Reply #78 on: November 07, 2015, 12:54:37 pm »
Indeed, that is useless for many reasons. But the opinion here is that the IET is the same as the DEREE. And I just tested it because I became curious. I measured the ESR at 100kHz from a 6800uF cap with my IET DE5000. This was 0.023 ohm. So you do something wrong or the meters are not equal.
Offline kripton2035
« Reply #79 on: November 07, 2015, 01:00:33 pm »
measuring a 2200µF/25V (that's the biggest I have) with my DEREE gives 0.035? so I get the milliohm (@100KHz)
you must force the measuring system to measure Rs (and not in auto mode)
Offline Srbel
  • Country: cs
« Reply #80 on: November 08, 2015, 09:25:44 am »
OK, in Rs mode it can measure at 100 KHz. I have tried Panasonic 3.300 uF 25V and it measured 8 milli Ohm.
But, in DCR mode (not measuring capacitor, but a wire to measure resistance), I only get 10 milli Ohm resolution. I can only get 1 milli Ohm resolution in ACR mode. :/
So, what if I want to see what is the best inductor I have in terms of DCR?
Offline Deathwish
  • Country: wales
« Reply #81 on: December 04, 2015, 12:14:35 pm »
mine came the other day, seriously its built like a tank, I mean, does it really have to be the size of a house brick !. I could use it to float across the channel to France on.
Electrons are typically male, always looking for any hole to get into.
trying to strangle someone who talks out of their rectal cavity will fail, they can still breath.
God hates North Wales, he has put my home address on the blacklist of all couriers with instructions to divert all parcels.
