Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Products
Test Equipment
Tektronix 2445B vertical problem (solved)
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Tektronix 2445B vertical problem (solved) (Read 1824 times)
mmaseda
Contributor
Country:
on:
October 02, 2016, 08:10:36 pm »
I was using my 2445B today and noticed that when using the vertical position knob that the amplitude of the waveform gets larger as it is moved towards the bottom of the display. This happens on both channels 1 and 2 but not on 3 and 4. See attached pictures. Any ideas what the problem is ?
Last Edit: October 03, 2016, 03:12:30 pm by mmaseda
Logged
Orange
Frequent Contributor
Country:
Re: Tektronix 2445B vertical problem
Reply #1 on:
October 03, 2016, 06:56:53 am »
I would start by checking the power supplies first. If that is within reasonable limits. You probably have a faulty channel switch hybrid
U400, 155-0236-00
It's a common malfunction in the 2445/2465 series.
Logged
mmaseda
Contributor
Country:
Reply #2 on:
October 03, 2016, 01:45:55 pm »
U400 was the problem. Thanks !!!!
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Products
Test Equipment
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
