Author Topic: Backup Firmware DG1022  (Read 16290 times)
Offline JimKnopf
Re: Backup Firmware DG1022
« Reply #50 on: August 16, 2021, 07:44:08 pm »
@tv84 Oh, i see. I was too quick. I extracted the files:
find ./ -name '*.ldr' -exec md5sum {} \;
698cd8eb479c8dce5b85e9478ae098ac  ./examples/tv84/DG10x2_Update.ldr
a1d5cd44227fe07e44de9d6e6b0dde7f  ./examples/tv84/bootloader-tv084-v1.ldr
698cd8eb479c8dce5b85e9478ae098ac  ./DG10x2_Update_Last_LDR_00.02.07.00/DG10x2_Update.ldr
698cd8eb479c8dce5b85e9478ae098ac  ./dg1000_latest/LDR/DG10x2_Update.ldr
698cd8eb479c8dce5b85e9478ae098ac  ./dg1000_/DG10x2_Update.ldr
Indeed it's this LDR file i tried.
Offline tv84
  • Country: pt
« Reply #51 on: August 16, 2021, 08:09:39 pm »
Here is the flash dump that should give you FW 02.12.00 with Bootloader 03 already included.
It should allow for a direct stock 00.03.01.00 .GEL flash (which I think is the latest AFAIK).
Try and report.
Edit: removed file as it was not OK.
« Last Edit: August 17, 2021, 06:42:04 pm by tv84 »
Offline JimKnopf
« Reply #52 on: August 17, 2021, 10:08:02 am »
@tv84 I programmed the flash memory and tried to boot. All illuminated buttons light up, device will not start.
Offline tv84
  • Country: pt
« Reply #53 on: August 17, 2021, 06:41:21 pm »
Jim,
Version 2.10 with your settings. Extracted from a working unit.
Test and report.
The following users thanked this post: JimKnopf
Offline JimKnopf
« Reply #54 on: August 18, 2021, 05:45:56 pm »
@tv84 Thanks again.
The device booted with your latest firmware file. To speed things up, i build an adapter with flying wires soldered to the pads on the board and to 2x 24-pin-headers. Now i can switch the TSOP48 programming socket from the programmer to the adapter quickly without solder/desolder the chip every time.
I tried to update the bootloader using the menu. But i couldn't recall a GEL file. I did it like mentioned here:
https://www.eevblog.com/forum/testgear/rigol-dg1022-how-to-update-the-firmware/msg592701/#msg592701
After updating the bootloader, the device won't start. I just did the same proceding with the firmware update GEL file and the device started.
The only thing was, some keys were locked. I fixed it like mentioned here:
https://www.eevblog.com/forum/testgear/rigol-dg1022-how-to-update-the-firmware/msg3261146/#msg3261146
I just put a USB-Stick with the unlock.scpi file into the device and used the recall function. After that, the keys working normal.
Maybe i have to recalibrate the device.
Many thanks for your effort.
@tv84 I attached the latest NVRAM dump after updating.
« Last Edit: August 18, 2021, 09:25:25 pm by JimKnopf »
Offline tv84
  • Country: pt
« Reply #55 on: August 18, 2021, 07:02:07 pm »
Jim,
 :clap:  I was hoping for you to solve the rest!  :)
Now, update to 03.01 and send me the new dump. You used 03.00.  ;)
Offline JimKnopf
« Reply #56 on: August 18, 2021, 07:19:55 pm »
For sure I downloaded and installed the latest version DG1022X(DSP)Update(Normal)_00.03.00.00.01 from the Rigol site.
Offline tv84
  • Country: pt
« Reply #57 on: August 18, 2021, 07:23:13 pm »
Nope, this is the latest.
Offline JimKnopf
« Reply #58 on: August 19, 2021, 09:25:23 am »
@tv84 Ok, i didn't notice that there are several sources on Rigols sites with different "last" versions:
rigol.eu
rigolna.com (03.00 is the last version)
rigol.com (03.01 is the last version)
I updated without errors to 03.01.
Offline tv84
  • Country: pt
« Reply #59 on: August 19, 2021, 06:38:26 pm »
 :-+  Thread closed.
