Hi!
I've got an AWG2020, which did not power on. After cleanup of the boards, replacement of all 22uF caps and repair of corroded traces the generator sprung back to life, except one failure in the output circuitry. It looks like the error is caused by damage on the A3 board. It was most likely caused by leaking caps, but this time the damage to the traces is not as extensive as on other boards, but the SMD resistors around the input circuitry are damaged. The top protective layer peeled off exposing the resistive traces, and along with the top layer the markings also disappeared.
Can somebody, please, take a picture of this section of the board with resistor markings readable?
