Author Topic: Tek TAS 465: How to fine-tune Volts/Div  (Read 64 times)
vk6zgo and 2 Guests are viewing this topic.
Offline allenwpTopic starter
« on: Yesterday at 06:57:31 pm »
Hi there,
I have a Tektronix TAS 465. I can easily adjust the Volts/Div at a coarse scale, such as 1 V, 500 mV, 200 mV, 100 mV, 50 mV, etc. How do I have more fine control of the Volts/Div? I noticed there is a "VAR On/Off" setting in the Vertical Menu, but turning that on doesn't change the behaviour of the Volts/Div dial.
I've tried searching through the manual that I've linked, but I can't seem to find instruction on how to set the Volts/Div to something like 735 mV, for example.
Is anyone here familiar with this line of oscilloscopes or is able to find instructions on how to do this?
Thanks!
Re: Tek TAS 465: How to fine-tune Volts/Div
« Reply #1 on: Yesterday at 09:42:01 pm »
Hi there,
It won't.
The fine Var will however change the amplitude of the waveform.
A DSO OTOH will display the V/div when in Fine mode and measurement cursors can provide accurate values....within the limits of what a scope can resolve.
