Hi,NI has removed all the vintage driver from the their homepage. I can't find any link for downloading Windows 98SE drivers for NI GPIB ISA cards in the net. Any hints where I can find this driver package?Thanks...
Quote from: chronos42 on May 08, 2020, 05:23:10 pmHi,NI has removed all the vintage driver from the their homepage. I can't find any link for downloading Windows 98SE drivers for NI GPIB ISA cards in the net. Any hints where I can find this driver package?Thanks...Guessing I would have it archived. What is the cards part number and I will check to see.
This thread is a reminder to hug your standardized VXI11 ethernet<->gpib adapter today if you haven't already.No drivers = best drivers.
Thank you Joe. Meanwhile a forum member helped me to get the driver package. And I learned my lesson (again): Save every Software you have downloaded in your own archive, even when the company offered all their released software on their site since decades without any restrictions. Never trust that this will last for ever!
Quote from: chronos42 on May 08, 2020, 05:23:10 pmHi,NI has removed all the vintage driver from the their homepage. I can't find any link for downloading Windows 98SE drivers for NI GPIB ISA cards in the net. Any hints where I can find this driver package?Thanks...I am also looking for a driver for a NI PCI GPIB card for windows XP service Pack 3 and/or windows 7. The card assembly number is 182820C-01. Any help is much appreciated. Thank you.
but I have a ISA PCII/IIA GPIB interface from National Instruments as well...From what I understand Windows ME is the latest os that can be used, is this correct?Can you please send the drivers to me, too?
National Instruments NI-488.2 for Windows.Version 1.70.Copyright 2000 National Instruments Corporation.All Rights Reserved.NI-488.2 for Windows, Version 1.70, supports the following hardware: Windows Me/98/95 Windows NT Windows 2000 ================ ========== ============AT-GPIB/TNT Yes Yes YesAT-GPIB/TNT (PnP) Yes Yes YesAT-GPIB/TNT+ Yes Yes YesGPIB-1394 Win98 and WinMe No NoGPIB-ENET Yes No NoGPIB-ENET/100 Yes No NoGPIB-PCII Yes No NoGPIB-PCIIA Yes No NoGPIB-USB Yes No NoNEC-GPIB/TNT Yes No NoNEC-GPIB/TNT (PnP) Yes No NoPC/104-GPIB Yes Yes YesPCI-8212 Yes Yes YesPCI-GPIB Yes Yes YesPCI-GPIB+ No Yes YesPCMCIA-GPIB Yes Yes YesPCMCIA-GPIB+ Yes No YesPMC-GPIB Yes Yes YesPXI-8156 Yes Yes YesPXI-GPIB Yes Yes YesVXI/VMEpc-650 Yes Yes YesVXIpc-745 Yes Yes YesVXIpc-850 Yes Yes YesVXIpc-860 Yes Yes YesVXIpc-870 Yes Yes Yes
The readme for NI-488.2 for Windows, Version 2.0 doesn't list support for any ISA bus GPIB controllers.The readme for NI-488.2 for Windows, Version 2.2 says that the support for the ISA bus AT-GPIB/TNT(PnP) is new in that version.
Supported Interfaces--------------------NI-488.2 for Windows, Version 2.0, supports the following hardware onWindows 2000/XP/Me/98. Any special requirements or conditions arestated below the list in the Notes section.GPIB-ENET GPIB-ENET/100GPIB-USB-A GPIB-USB-BPCI-GPIBPCI-8212PMC-GPIBPXI-GPIBPXI-8212Notes: 1) Neither the Controller nor Analyzer functionality of the PCI-GPIB+ interface is supported in Version 2.0. 2) The GPIB-ENET product is obsolete. The interface is supported in Version 2.0, but it should not be used for future designs. Use the GPIB-ENET/100 instead.
This post has a copy of the Readme file for NI-488.2 for Windows, Version 2.0:https://www.eevblog.com/forum/testgear/setup-help-with-ni-gpib-usb-a-and-b-on-windows-7/msg4087360/#msg4087360It has no mention of any ISA bus GPIB controller as a supported interface. That information might be more accurate than the "GPIB Hardware Guide.pdf", which might include information on interfaces that are no longer supported.Code: [Select]Supported Interfaces--------------------NI-488.2 for Windows, Version 2.0, supports the following hardware onWindows 2000/XP/Me/98. Any special requirements or conditions arestated below the list in the Notes section.GPIB-ENET GPIB-ENET/100GPIB-USB-A GPIB-USB-BPCI-GPIBPCI-8212PMC-GPIBPXI-GPIBPXI-8212Notes: 1) Neither the Controller nor Analyzer functionality of the PCI-GPIB+ interface is supported in Version 2.0. 2) The GPIB-ENET product is obsolete. The interface is supported in Version 2.0, but it should not be used for future designs. Use the GPIB-ENET/100 instead.In any case, in a week or so I should have access to a CD of NI-488.2 for Windows, Version 2.0. I will upload an ISO image of that CD when I am able to do so, and then an almost complete set of CD images for old versions of NI-488.2 for Windows should be available.
