Author Topic: GDS-2000A series New economic oscilloscope by GW Instek comes to market  (Read 146047 times)
Offline grego
Re: GDS-2000A series New economic oscilloscope by GW Instek comes to market
« Reply #450 on: August 13, 2013, 03:15:48 am »
Have you seen this competitive datasheet DPO2000B vs. GDS-2000A?
Marketing speak.  Honestly, Tek needs to get their crap together and come out with something people really want.  They are getting killed in the lower end scope ranges.
Notice (not that this is the only real point of comparison mind you) that they don't even mention wfm/s?  That's because the Tek is only 5000 wfm/s max whereas the Instek is 80,000.  That's not a metric you want to highlight.
Offline HydrawerkTopic starter
« Reply #451 on: August 13, 2013, 03:51:24 pm »
Well, Tektronix DPO2000B can have active probes (that are bloody expensive). But that is not a big advantage for a hobbyist.
Offline echen1024
  • 15 yo Future EE
« Reply #452 on: August 13, 2013, 08:39:14 pm »
I don't think their target market is hobbyists. I think they are targeting the 1000 unit/order, institutional type.
I'm not saying we should kill all stupid people. I'm just saying that we should remove all product safety labels and let natural selection do its work.
https://www.youtube.com/user/echen1024
Offline Yaksaredabomb
« Reply #453 on: August 13, 2013, 09:49:10 pm »
... I think they are targeting the 1000 unit/order, institutional type.
I wonder who would possibly have a need to order 1000 scopes at once?  Maybe if all the universities in a state (or several states) all got together and decided on one?
Not meaning to be critical or take you too literally - it just provoked my imagination and now I'm wondering.
My display name changed June 6th from "jneumann" to "Yaksaredabomb"
Offline echen1024
  • 15 yo Future EE
« Reply #454 on: August 14, 2013, 04:48:05 am »
I don't know either. Just a random figure. :-//
« Reply #455 on: August 16, 2013, 12:23:02 am »
There is new firmware for this scope that fixes a lot of stuff apparently:
http://webfile.gwinstek.com/ftp/GDS-2000A/GDS2K_V1.17.upg
Will go install it now.
So is the scope better now? Was the intensity grading feature improved?
« Reply #456 on: August 30, 2013, 06:42:37 pm »
Now GW Instek published their firmware directly on their website. That's good. http://www.gwinstek.com.tw/en/product/productdetail.aspx?pid=3&mid=7&id=1349
Go to the Download section. Then go to the Software section.
Also please download the Firmware upgrade guide.
« Last Edit: August 30, 2013, 06:47:10 pm by Hydrawerk »
« Reply #457 on: August 30, 2013, 08:57:39 pm »
Sweet!  That is good news - thanks!
Offline marmad
  • Country: aq
    • DaysAlive
« Reply #458 on: September 07, 2013, 04:50:22 pm »
Sadly I'm still swamped and haven't had a chance to try out the update myself.  We'll see about this weekend.  I hope the knob sensitivity adjustment smoothes out the knob action.  The enhanced SW and VPO performance also sounds great - maybe someone will be clever enough to find a way to measure the performance improvements?
How about a report on the waveforms per second rate when you have the DSO set to AUTO record length? Using the tiny 1k SHORT length (which is how they measure their 80k wfrm/s) is a serious drawback for getting decent sample speeds at most timebases - so I'd like to see an honest chart reflecting the wfrm speeds when using a reasonable record length size.
« Reply #459 on: September 07, 2013, 10:27:04 pm »
And what do you think about the Trig Out signal? It has a very low level. Kiriakos wrote:
c) The Trigger-Out has an voltage range not higher than 200 mV AC, which varies significantly depending the time base of the scope and usually ranges from 120 mV to 5 mV and even less than that.
http://www.ittsb.eu/GDS-2102A%20Wfms%20measurments.html
But he was wrong with waveform update rate measurement...
Offline digsys
    • DIGSYS
« Reply #460 on: September 27, 2013, 12:26:17 pm »
Any updates on the GDS-2304A ? TM have a "show special?" at ~OZ$1770 (no options).
What was the comparison consensus / outcome? Thoughts?
« Reply #461 on: October 06, 2013, 10:32:52 pm »
New videos. Well, GW Instek guys should buy a HD video camera.
« Reply #462 on: November 09, 2013, 09:57:20 pm »
GW Instek GDS-2000A is now sold rebranded as Texio DCS-9700 Series.
DCS-9700????????
http://www.texio.co.jp/en/03prod_01_03_DCS-9700.html
Offline AndersAnd
« Reply #463 on: November 10, 2013, 07:03:56 pm »
Good Will Instrument Co., Ltd. [a.k.a. GW Instek] is now the owner of Texio [formerly Kenwood TMI] according to Texio's website:
Company: http://www.texio.co.jp/en/02comp_02.html
Shareholder   Good Will Instrument Co., Ltd.
History: http://www.texio.co.jp/en/02comp_03.html
...Established TEXIO TECHNOLOGY CORPORATION affiliated of GOOD WILL INSTRUMENTS CO.,LTD
Power supply and electric measuring instruments business have been transferred to TEXIO TECHNOLOGY from NIKKE TECHNO SYSTEM...
« Reply #465 on: March 21, 2014, 02:45:39 pm »
As Dave mentioned before, the VPO performance is not good at GDS-2000A scopes.
This is how it should look like.
http://youtu.be/_TSr9nFN1GU?t=12m20s
« Last Edit: March 21, 2014, 02:50:21 pm by Hydrawerk »
« Reply #466 on: March 21, 2014, 02:57:23 pm »
Other examples of good VPO performance.
Offline Prismattery
  • Country: ee
  • Power supplies and battery chargers.
« Reply #467 on: March 24, 2014, 08:58:17 am »
Fast question. This GW instek GDS-2072A vs RIGOL DS2072A. Which one to choose?
Will be used for hobby projects and some more advanced power electronics projects.
Joonas Karu
Prismattery LLC
« Reply #468 on: March 24, 2014, 12:54:37 pm »
For 70 MHz, 2 analog channels, and no digital channels most will probably agree the Rigol is better.
I wanted more bandwidth (200MHz) and 4 channels, though, so I went with the Instek as it was far more cost effective than anything else with the same specs at the time I bought it.  Plus there was a great deal on the 8-channel LA option at the time (slightly over 50% off) so I went for that too - which wouldn't have been a possibility with the Rigol.  Sadly I *still* have yet to use it much so I can hardly say anything about how well I like it.  There are several hobby projects I was pretty excited about but the rest of life keeps getting in the way.
Good luck!
Offline Joel_l
« Reply #469 on: April 08, 2014, 02:19:55 am »
I'm thinking about returning the Siglent SDS1204 I just bought ( not very happy with many aspects of it ) and trying the GDS-2204A. I see that there has been several FW updates since the lack of a fine adjustment on the vertical scales was brought up and fed back to Instek. Does anyone know if fine vertical adjustment been added?
Thanks
Joel
« Reply #470 on: April 08, 2014, 02:35:07 am »
I do not think so... Fine control was not added IMHO.
It seems that this scope is suitable for you if you need quite cheap four channel  scope and you do not need good VPO performance or high waveform update rate. Also the search function might be useful. You have probably seen Dave's video, have you?
Note the crap function generator. Nowadays you can buy Rigol DS2000 with arbitrary generator.
On the other hand, GW Instek will last longer IMHO. It does not have such a powerful hardwware, but it should be durable.
And I think that even that expensive GDS-3000 series has no fine vertical control.
Contact your authorized dealer for more info.
Offline Joel_l
« Reply #471 on: April 08, 2014, 02:52:41 am »
I did watch parts of Dave's video ( a lot of skipping ahead ). What I want from a scope I thought was basic, stable display of simple wave forms and reasonably accurate measurements. I get neither from the 1204. It would also be nice to have independent control of timebase and sample rate within the abilities of the scope and memory depth. On paper the GDS -2000A's look interesting.
Joel
« Reply #472 on: April 08, 2014, 08:06:55 pm »
Oh, was it so bad with that Siglent? They sell the same model as LeCroy WaveAce, I think. http://teledynelecroy.com/oscilloscope/oscilloscopemodel.aspx?modelid=6886&capid=102&mid=504
Offline Joel_l
« Reply #473 on: April 08, 2014, 10:17:39 pm »
I did hear back from Siglent on my issues and they said they were addressed in the latest firmware. Now I waiting to hear why FW x.12 (on their website) is later than FW x.33 ( on my scope ). In the end, if the issues are addressed, I will be happy with the 1204. To keep things on topic in this thread, see my thread SDS1204CFL to track progress on this issue if you are interested.
Joel
« Last Edit: April 08, 2014, 10:23:46 pm by Joel_l »
