At the moment however, the value of the licenses + MSO + wavegen is approximately $5k (USD), ignoring MSO cabling. It would be worth recovering if you want legitimate licenses. However, the recipient unit would be what the donor unit was, unless you hack it, which sort of defeats the purpose of the "recovery".
And, I don't know which package the NAND flash is in, but you better be good at removing with minimal heat. Packages are usually only specified for three times or so (one side solder, second side solder, repair).
