Hi bxs,
Could I please ask what you think about your Atten ADS1102CAL?
Many Thanks
Stephen
Hi Stephen,
I think you are asking if Atten ADS1102CAL it's a good buy, so I will try to answer that.
It's a hard and at the same time a simple question, it's hard because we always want the most for the less($ €) and is simple because all those cheap DSOs are just toys
![Wink ;)](https://www.eevblog.com/forum/Smileys/default/wink.gif)
So in my opinion for just a few hundred $, let say 3 or 4 you are buying a toy not a real thing.
In my case I wanted something to have at home that could give me basic functions, sometimes just gathering dust and it needed to be cheap and ATTEN checked the requirements.
When I bought it, the only thing at +- the same price was the rigol(50MHz), this ATTEN was 100MHz and had a better LCD. Note that I knew about the hack of rigol 50 to 100MHz, but I didn't want additional work to get the 100MHz.
About my experience with my ATTEN, it as been good for the most part, what I really don't like are some bugs, that in rare situations force me to restart the scope.
I read about people with same/similar ATTEN scopes with the same problems, and some of them got a firmware update for fixing those, I also tried to get one once, but is was just a nasty experience, lets say that I contacted ATTEN with all the data about my scope and they replied asking again for exactly the data that I had already send, it was so stupid that I simple quite trying
![Sad :(](https://www.eevblog.com/forum/Smileys/default/sad.gif)
So this days if someone buy a new ATTEN they probably get it with new firmware, but it's a gamble.
The Rigol seems better in support, but you should never expect real support for cheap scopes, most of the times what you buy is what you will get
To some up, at the end of the day the scope as been doing the job
![Cheesy :D](https://www.eevblog.com/forum/Smileys/default/cheesy.gif)
, note that I stop looking for scopes since I bought mine, I'm sure that these days exist better ones, from ATTEN and others.
