I have an old ATTEN ADS 1102CA+, never had much luck with the triggers, so shelved it, then read on this forum how to update. I did the update, however, now I've lost the menus (see pictures). I downloaded the files from Siglent site. However, the actual ADS in the CNL Zip was a CML...ADS (not sure if that matters, the FW may detect the memory size), The scope seems to work fine, just the menus are blind. Also, the zip files on the siglent site do not include the .CFG files - so I was not able to update that. any help appreciated.
photos attached.
Thanks,
Brian.
