Author Topic: HPAK branding - 34401A  (Read 1091 times)
Offline artagTopic starter
« on: September 22, 2019, 08:35:18 pm »
Does someone here have an Agilent or Keysight branded 34401A ?
If so, can you tell me whether the SCPI *IDN? command reports it as HP, Agilent or Keysight ?
Offline Kosmic
Re: HPAK branding - 34401A
« Reply #1 on: September 22, 2019, 09:36:55 pm »
Got an Agilent branded 34401a. Here's the answer to *IDN?
-> *IDN?
<- HEWLETT-PACKARD,34401A,0,10-5-2
« Last Edit: September 22, 2019, 10:15:09 pm by Kosmic »
« Reply #2 on: September 22, 2019, 10:01:29 pm »
Thanks.
Seems sensible, since after the rebranding they'd still want it to work with existing test applications
Offline Macbeth
« Reply #3 on: September 22, 2019, 10:14:53 pm »
Oddly the 34401A never had a serial number in it's *IDN? response, while almost every imitator does.
Offline chickenHeadKnob
« Reply #4 on: September 22, 2019, 10:34:54 pm »
This discussion has me curios, the Agilent 34461A has claimed  industry exclusive only 100% drop in scpi compatible to the 34401. So what does *idn say?.
I don't have one to test. I could see 2 possibilities, a software set compatibility  mode which results in HP 34401 response or it always replies 34461A, in which case not really 100% compatible, LOL catch-22
Offline mr.fabe
« Reply #5 on: September 23, 2019, 04:44:45 am »
On a 34461A
For compatibility purposes, use SYSTem:IDENtify HP34401A to return:
HEWLETT-PACKARD,34401A,<Serial Number>,ff.ff-pp.pp-mm.mm-gg.gg-bb-pp
https://literature.cdn.keysight.com/litweb/pdf/5991-2367EN.pdf?id=2334983
The following users thanked this post: chickenHeadKnob
