Author Topic: At last, Siglent's SDS5054X touchscreen DSO...  (Read 112861 times)
Online tv84
  • Country: pt
Re: At last, Siglent's SDS5054X touchscreen DSO...
« Reply #500 on: September 13, 2021, 04:14:07 pm »
I see legacy of Portuguese Inquisition is still alive at least in proverbs... >:D
Maybe. Those guys would extract "their" truth by punishment.  :D
Online 2N3055
  • Country: hr
« Reply #501 on: September 13, 2021, 04:34:28 pm »
Yep.. Bad times...
Offline luudee
  • Country: th
« Reply #502 on: October 05, 2021, 04:51:12 pm »
Guys,
can anyone help me to telnet in to my sds5000x ?
I've done it a year or so ago, but lost the telnet.ads, and don't  remember if I need to play
back to an earlier firmware, or I can use with the latest.
Many Thanks !
luudee
Can help with some tea money as well ...
« Last Edit: October 07, 2021, 05:49:59 pm by luudee »
Offline luudee
  • Country: th
« Reply #503 on: October 12, 2021, 06:07:02 pm »
Guys,
has anyone noticed a "Developer Options" menu with the latest FW upgrade ?
I wonder what the password is and what those options are :-)
Cheers,
rudi
Offline tautech
« Reply #504 on: October 12, 2021, 07:36:54 pm »
Guys,
Cheers,
rudi
Developer Options is just a rename of the previous Debug menu.
Best left alone.  ;)
Online Martin72
  • Testfield Technician
« Reply #505 on: October 14, 2021, 08:00:53 pm »
Maybe it´s because of the launch of the new 6000 series, Welectron offer the 1Ghz model for under 5000  (excl.VAT):
Probably the cheapest 1Ghz 4-Ch Scope at the moment
Or it´s a mistake from them (they sell off the 2-ch models), batronix or siglenteu for example got the normal prices.
(Kierkegaard)
Offline 0xdeadbeef
« Reply #506 on: October 25, 2021, 04:38:42 pm »
There's a little bugfix update 0.9.5R3
https://www.siglenteu.com/service-and-support/firmware-software/digital-oscilloscopes/
0.9.5R3
1. Supported CAN-H, CAN-L as decode sources
2. Fixed several bugs
   a) Unexpected skew between channels after Stop in Roll mode
   b) Some trigger setting with dual-level may lead the scope not to start-up properly
Offline jemangedeslolos
« Reply #507 on: October 27, 2021, 08:16:45 am »
Lecroy have just launched their new oscilloscope T3DSO3000.
Starting from 200Mhz for only 4345€  ;D
 I am too fucking stupid to understand these marketing/selling practices  :palm:
Offline bson
« Reply #508 on: November 07, 2021, 09:38:03 pm »
So my SDS5034X will be on its way tomorrow.
Anyone know if they still have the well-know root password?
Online tv84
  • Country: pt
« Reply #509 on: November 07, 2021, 09:57:11 pm »
For telnet in SDS5000X use this fused with this.
The following users thanked this post: bson
Online Martin72
« Reply #510 on: November 07, 2021, 10:10:29 pm »
First you pay more because now it´s a lecroy... 8)
Second, all the options (except MSO and FG) are implemented from the start on, regardless of any promo-offers.
But....
200Mhz ?! and then this price....Oh-oh lecroy... :palm:
(Kierkegaard)
Offline bson
« Reply #511 on: November 07, 2021, 10:56:33 pm »
Very cool, I think I have all I will need.  Except, well, the scope ID. :-+
Just to confirm: it's safe to just delete or rename the bandwidth.txt file on the 5k?
Online tv84
  • Country: pt
« Reply #512 on: November 08, 2021, 12:06:33 am »
Don't go down that rabbit hole. Use the keygen.
Offline bson
« Reply #513 on: November 08, 2021, 12:27:19 am »
Oh I see, I was definitely going to generate a 1000M key, but thought the file also had to be removed.  In that case I don't believe I'll need to telnet at all?
Offline bson
« Reply #514 on: November 12, 2021, 08:10:17 pm »
Received my scope, tried to install a BW option; wasn't accepted.  So installed SENT, which was accepted.  Installed MANC and the instrument locked up.  Power cycled it, and it now locks up every time I try to go to the Options screen.  Upgraded the firmware to 0.9.5R3, still locking up.  Is there a way to factory reset this?
Edit: resolved by issuing "LIC:DEL MANC" over the webui's SCPI interface.
« Last Edit: November 12, 2021, 08:55:43 pm by bson »
Offline bson
« Reply #515 on: November 12, 2021, 08:41:53 pm »
It's also showing a Developer Options softkey.  Is this because it detected some kind of inconsistency?  Can it be used to reset the installed options?
Online tv84
  • Country: pt
« Reply #516 on: November 12, 2021, 08:48:21 pm »
Our kiwi friend should have the answers. The Developer Options is normal.
Offline bson
« Reply #517 on: November 12, 2021, 09:07:18 pm »
So... some observations:
- The 500MHz passive probes are physically identical to LeCroy 500M PP020 probes.  Same accessory baggie, same witches' hats, etc.  They auto detect as 10:1 automatically.
- It came with all options permanently enabled, except BW, SENT and MANC.  So included the MSO license; good thing I didn't buy it!
- This includes FG, PA, 1553B, I2S, Flex, CAN, MSO.
- The touch screen is really good - must be capacitive?
- The 500M upgrade works good, rise time (10-90) dropped from 0.95ns to 0.65ns.  (Using a Leo Bodnar pulse gen.)
After installing the 500M option though there is no way to upgrade it further.
Online tv84
  • Country: pt
« Reply #518 on: November 12, 2021, 09:46:02 pm »
Sure there is.
MCBD <lic>
Offline bson
« Reply #519 on: November 12, 2021, 10:51:36 pm »
That scpi command appears not to work with 0.9.5R3.  Might need to install an older firmware.
Offline bson
« Reply #520 on: November 12, 2021, 11:10:41 pm »
Problem solved.  0.9.3R3 is the solution.
Offline tautech
« Reply #521 on: November 12, 2021, 11:18:38 pm »
Now pop Leo's pulser on it and see what you get.
Can validate the result with one I have here and SDS5104X.  :popcorn:
Offline bson
« Reply #522 on: November 12, 2021, 11:29:06 pm »
550ps 10-90, averaged over a few thousand measurements.  Just over 800MHz.  It pleases me greatly.  ^-^
« Last Edit: November 12, 2021, 11:31:51 pm by bson »
Offline tautech
« Reply #523 on: November 13, 2021, 12:22:43 am »
One I nabbed a few weeks back.
SDS5104X with shiny new Leo Bodnar pulser:
The following users thanked this post: Leo Bodnar
Offline bson
« Reply #524 on: November 13, 2021, 01:28:06 am »
What's the difference?  Did they just add a little bit of input shunt capacitance to the 350/500 models? :)
Or maybe it's a lower-capacitance PCB stackup for the 1G...
