Hi Techneut,
Yes the script is working. As you have also the original keys for some functions you can easily check if your input is correct. MANC en SENT might not yet be included in your script and can be added manually. As TV84 stated there is only one key per item possible.
That is my problem, I am comparing the script against the originals and I have no match and I triple checked my input.
@Tautech:
I already contacted Batronix and they have been very helpfull sofar.
Good.
![Smiley :)](https://www.eevblog.com/forum/Smileys/default/smiley.gif)
Remember you have 30 trial uses of any option which should last you a week or 2 so they can sort out what the option license problem is.
The FG option is not realy an issue because I have a SDG2042X. It's only nice to have all options activated
For SDS5kX you must have the SAG1021I AWG USB module to use the FG option.
SDG2042X is by far the better option.
I still can't get the optionkey's right.
The script is working for the bandwith, With MCBD? I get the same code for 350 MHz so that works.
I entered the serialnr. through copy past from *IDN? so no typing errors.
I tried 'IIS' and 'I2S', both not giving the correct key.
If anyone has an idea please feel free to help,
that's how it worked for the SDS1000X-E and I missed it if it was mentioned in the tread.
Thanks for pointing it out.
As pointed out before, only the Scope ID is used for both, the bandwidth upgrade and the options.
After upgrading to 0.9.5R1 accepted the scoop the FG licence. I don't know if it was a problem with version 0.9.3R3 or that it just needed a kick.
Just for information.
There is this bug with the SDS5000X that a license can't be entered if it's the last in the list. As far as I recall, 0.9.3R3 added the SENT and Manchester decoders, so they are now last in the list. I was not able to enter the key for the Manchester decoder because of this bug and needed to use the LCISL command. Btw: there is a 0.9.5R1 since end of April.
Not here either:
https://int.siglent.com/download/firmwares/?ProId=4Outdated I guess and not required for any firmware upgrade stages.
The Firmware Revision Record and Upgrade Instructions list all the firmware upgrade steps when/if any are necessary.I have 0.9.5R1 if anyone requires it however being 64MB it will require a sharing website to be uploaded to.
Not here either:
Outdated? It is the latest version (4-30-2021)
I installed it last week but now I'm wondering if there is something wrong with it and better roll back.
Not here either:
My mistake sorry.
![Face Palm :palm:](https://www.eevblog.com/forum/Smileys/default/facepalm.gif)
Email sent to Siglent.
Reply received.
Version 0.9.5R1 has been removed and a replacement will be available soon.
The update is available now
5/22/2021 0.9.5R2 Fixed a bug which may cause failure on installation of option key in 0.9.5R1.
I wonder if they finally fixed the bug that made it impossible to enter the key for the last option in the list. Then again, that one existed for at least a year.
I'm considering getting a 1GHz bandwidth scope, and price is a concern. How is the SDS5000X looking these days? That bandwidth upgrade offer is attractive, but the June 2019 EEVBlog video review was pretty harsh regarding the UI. I see there have been a lot of updates, what is the general consensus on the usability, performance, and feature set of the latest version?
In some respects it now lags behind the SDS2000X Plus in terms of the features added since release and the front panel layout however I still enjoy using mine.
The promo is only available until the end of this month but some dealers should still have promo stock past that date and those with previous stock of the 500 MHz model should be able to get the BW update license for a new sale and apply it.
However it will still be badged as the 500 MHz model although screenshot filenames will report it as the 1 GHz model.
AFAIK both the LeCroy and Tek active probe adapters are also now available although only the LPA10 is showing on the US website.
Oh and BTW, the SDS6000 range I believe is not too far away:
https://www.eevblog.com/forum/testgear/siglent-sds6000-pro-10-and-12-bit-dso-coming/
I suspect it could be but really IDK.
We have a portuguese saying: those who tell the truth don't deserve punishment...
We have a portuguese saying: those who tell the truth don't deserve punishment... ![Cheesy :D](https://www.eevblog.com/forum/Smileys/default/cheesy.gif)
I see legacy of Portuguese Inquisition is still alive at least in proverbs...
