Very first impressions before this SDS5034X must go to my customer.
Big display, the same physical size as those used for SSA and SVA models.
Super quiet fan that make some little noise when booting but slows to nearly inaudible before boot has finished.
SDS5034X (350 MHz) comes with 10x auto-sense SP3050A 500 MHz probes.
They have 1x LF and 2x HF compensation adjustments in the BNC box and with the normal accessories like a spare needle tip, probe to BNC adapter and ground spring.
https://siglentna-qwavztc8hvq2w.stackpathdns.com/wp-content/uploads/2019/02/SP3025A_3050A_Users_Guide.pdfThe scope is a joy and simple to use, front panel layout is good and intuitive.
Knobs are rubber coated like we've seen in SDS2000X models.
Touch display works just fine even through the factory screen protector tear-off and can be toggled ON or OFF.
Rear VGA ports to an external monitor perfectly with zero visible latency.
The current factory firmware is 0.8.2R1 The full string from the webserver info is: 4.6.0.8.2R1
SN# indication: SDS5XDAD2R0***
Some meaningless play screenshots.
Ch4 1 MHz 1V p-p from SDG1032X for probe HF adjustments*. (*SDG1032X risetime marginal)
Connection via BNC adapter to SP3050A 10x probe.
Ch1 500 MHz 0dBm from SSG3021X
Connection: Siglent 6 GHz rated N-N cable with unknown N-BNC adapter.
One thing is quite an improvement on other/older Siglent models is the Zoom display proportioning.
This shot shows a much improved ratio of the un-zoomed and zoomed working area.
