Author Topic: Rigol DS2072A vs DS2072A-S  (Read 5536 times)
Offline mrpacketheadTopic starter
  • D Size Cell
« on: October 25, 2015, 07:38:31 am »
Is there any difference in the hardware of the 2072A vs the 2072A-s Version... It seems there is, but I was'tn 100% certain..
Offline Roeland_R
Re: Rigol DS2072A vs DS2072A-S
« Reply #1 on: October 26, 2015, 09:24:26 pm »
From Rigol website:
The Rigol DS2072A is a multi-functional high performance digital oscilloscope. Standard features include - Sensitivity down to 500μV/div, record, replay & analysis functions, selectable 50Ω input impedance and 8" WVGA display with 256 grading levels. Furthermore, it possesses a variety of trigger functions, decoding functions, connectivity options, mathematical operations including FFT, automatic waveform measurement parameters with statistics, a pass / fail test and a built-in help system. A two channel 25MHz function / arbitrary waveform generator is included on '-S' models. The Rigol DS2072A is a versatile instrument that offers useful performance and features at a very competitive price.
Offline crispy_tofu
« Reply #2 on: October 26, 2015, 10:47:28 pm »
I wonder if it's just a software-configurable feature...
  • D Size Cell
« Reply #3 on: October 27, 2015, 07:31:36 am »
like everything else in Rigol Land. One unit, with software features.
Does a 2072A have the output connectors on the back?
Offline donkey77
« Reply #4 on: October 27, 2015, 08:29:52 am »
I've got the -s version. I don't think the standard version has the extra 2 BNC connectors on the back or the source button to the left of the jog dial.
Offline tec5c
« Reply #5 on: October 27, 2015, 08:40:03 am »
Isn't the only difference being that the '-S' model has a built in sig. gen.? Hence, same hardware...
Offline Ivan7enych
  • Country: ru
    • My astronomy projects
« Reply #6 on: October 27, 2015, 09:51:39 am »
Check the teardown
There's no sig gen output connectors and obviously no sig gen board.
Offline crispy_tofu
« Reply #7 on: October 27, 2015, 09:56:47 am »
Not sure if there's any difference, but the one in the teardown is a DS2202 and not a DS2072...
Offline tec5c
« Reply #8 on: October 27, 2015, 10:07:00 am »
It's only a bandwidth difference. 200meg vs 70meg
Offline crispy_tofu
« Reply #9 on: October 27, 2015, 10:13:59 am »
Okay, so that means that it's most likely software-enabled.
Which means that the DS2202 is the same as the DS2072
And the DS2202 doesn't have a signal analyser
Therefore, there is a difference in the hardware between the DS2072A and the DS2072A-S  :-+
Offline Ivan7enych
  • Country: ru
« Reply #10 on: October 27, 2015, 10:21:02 am »
DS2202 and DS2072 are hardware identical
DS2072A has 50om termination on inputs (small hardware change)
I think there's no software key to turn on signal gen or logic analyzer on DS2072A model, I think the firmware checks if hardware is present, and than uses it and shows additional menus.
